Sram Chain
T.McMillan
I was just riding along as you do. and I was just lineing up to do a drop only about 3ft off of a cable drum onto a slopped pallet and roll off, easy as walking basically. Anyway did a few pedal hops to the edge of the cable drum lineing myself up and did a hard pedal hop to get myself onto the slopped pallet, and........BANG! I was like what the hell happened there, launching my self slightly over the handle bars and before i knew it I was impacting the tarmac drive outside my house, OUCH! Managing to cut my hand leg and armpit (dont know how i managed the armpit really hurts though lol)
This was the first occuranse of this happening to me. oh yes you've guessed it, my chain snapped. I looked at my chain rolling it off the casette and it was the bloody gold magic link that sram supply you with the chain.
The chain I use is a Sram PC59
Everybody probably knows this problem already but i thought just to warn you guys out there dont use the gold magic link they supply with the chain. I am just going to join my chain with a REAL link so it shouldnt break again. MAGIC MY ARSE
Does anybody know of a good chain for a 9speed casette?
Here are a couple of pictures of the bloody "gold magic link" not so magic in my opinion now (N)
IPB ImageIPB Image
Cheers for looking
Tom
hey,i've never snapped a 9 speed sram chain,i think they're quite good.you should never join a chain with the split links.i'd get another sram one but join it without the split link using a decent chain tool like the park mini brute,they're really good.alternatively go for a thicker chain like the kmc's and run less gears.
hope it helps a little
craig
IPB ImageIPB Image
Cheers for looking
Tom
You found out the hard way too!
The sram chains are seriously strong, but dont ever use the power link! ever
just use a chain tool to do a proper join, put some tip ex or paint on your join to keep an eye on it.
(Y)
I personally always use the provided split link. the SRAM ones are possibly the weakest design, but there still pretty strong and ive never broken one. While it is possibly the weakest link in the chain, it is likely to be stronger than joining the chain yourself.
If your doing this repeatedly, then its a justified opinion- but just one breakage could be unfortunate. could have been defective from the factory ect.
hello ollie.
on the 3 occasions ive had bad crashes and hurt myself and my bike ,,,,,,,its been the split link.
trust me
they are good for normal riding ,,,,,,not for trials.
(Y)
The chain has lasted for ages at least a year i just think the magic link was in the place where it gets the most amount of pressure applied, which should be just before the chain ring. I wasn't using a huge amount of force, it was literally rolling off the cable drum onto the slopped pallet, I am also a smooth rider. (Y)
Does a thin kmc kool chain work on a 9spd or is it deffinalty just an 8spd?
Tom
just cause it looks big , doesnt mean its stronger.
:D
Its all about the riding im afraid.
smoooooooooth.
The chain isnt at fault.
how smooth a rider you are doesnt determin when a chain snaps. think about it, your chain isnt affected by how hard you land. just how hard you kick. and just because you use a lot of power at the pedals doesnt mean you cant land smooth. and about the other comment. size of links has quite an important factor in strength of chain. Kmc chains are very strong
I had the same problem with my Sram PC58, snapped in exactly the same way.
The funny thing was i'd been ridding all day and nothing, but riding home...... just in the middle of a busy road.............SHNAP
Have been through 3 of them in about 6 months, anyone recomend anything stronger, running gears too
are you running 8 or 9 spd.
if its 8spd kmc kool all the way.
if its 9spd not sure, wipperman maybe. Or just change to 8spd.
mike
