Yet Another Control 09
freetrial
Here`s my current rig. Basically I just "transplanted" the vital organs from my Gu LE.
Spec:
Frame - Echo Control 09 Long
Fork- Rockman curved
Wheels - Echo SL with V!Z alu nipples
Stem/Bar - Trialtech
Crank/Freewheel/bashring - Echo SL
Brakes - Echo SL rear /Hope mono trial 190 front
Tires - Schwalbe MuddyMary rear / RacingRalph front
Weight: 9,33Kg on the parktools scale.
As fit as they come...
TR clamps rules
Halflink trickery for best geo with 18 / 15 ratio.
I likes...
whats the difference between the 2 frames would you say?
Control has a more responsive feel to it, probably due to the use of larger diameter tubing. Rear end is quite a lot shorter the way I run it, with the halflink. I was able to remove one inner and one outer link from the chain.
Rear brake is also a tad stiffer since the length of tubing between 4-bolt mount and upper chainstay weld is shorter.
I really liked the LE frame from the first day, but if I`d have to chose one frame to ride for the rest of my life, it would no doubt be the 09 Control.
Other frames I`ve had:
GT Zaskar
GT Ricochet
Azonic DS2
Echo ES4
Echo ES2
Echo Urban
BT RAven 5.0
BT Ninja 365
BT RAven 6.0
GU Typhoon 07
Gu TP 08
Koxx Karbon
GU LE
  • 3 months later...
What do you think of that rear tyre pros and cons please and what's the weight?
Stated weight from Schwalbe is 850g. I`ve cut some knobs of mine, and when I weighed it last time, the park tools scale said 730g.
The rubber is really tacky (gooey gluey compound), and really predictable. Snakeskin sidewalls gives great snakebite protection.
I`ve sworn by these tyres for the last two seasons.
When this one wears out, I`ll try out the new "wicked will" which has the same carcass, but different tread.
No con`s, really! Well pleased with it. :)
How thick are the sidewalls compared to a maxxis 2ply?
Thinner than Maxxis, thicker than Rubber Queen.
How is the stability on off camber rocks
Depends on tyre pressure I guess. Better than BigBetty.
& what preasure are you running?
Around 20Psi.
check them out on: www.schwalbe.de
I do recommend them, but as far as any bikepart goes, you`ll just have to try them out and see if they fit you and your style.
