Still No Way To Have Gears On A Trials Bike Without A Derraileur?
zoster
Houdy!
i have a 24".
going around town sucks with the trials ratio, but having a dérailleur also sucks. i am still waiting for some company to make a 2-geard hub / freewheel made for abuse! i know about the Hammerschmidt, but the price tag is ludicrous.
you could also use a tensioner that can be (sort of) easily moved from one cog to another, but this brutally separates the trials part of the ride from the commuting part, which takes away from the whole idea of a street-trials bike.
anyway, i think you all know what i am talking about, i was just wondering if some new product came along or anybody came up with a brilliant idea for this purpose, that we all missed.
Edited by zoster
It's hard enough to make a freehub which doesn't blow up when people use it for trials already, trying to do this with a multiple gear system inside would be asking for the world.
Not to mention it would weigh a ton in a sport where people are drilling holes out of their brake levers and cutting off tyre knobbles to save a couple of grams.
Just get a derailleur, they aren't as bad as your making out, if you're only using two gears you don't need a shifter either.
so what's stupid about it?
That´s exactly why
i was wondering this as im going to buy a street bike, i was just going to go with the tensioner off and chain onto a different cog then flick the tensioner back on method.
but i'd like to find out some other ways too, if anyone knows anyother ways.
Edited by cam217
I recently wanted to do this but got a rohloff instead. Look into the tensile, tryall or atoms tensioners. They look like they might have enough lateral movement to be able to quickly swap between cogs. I havent tried it so I dont know if it will work or not.
white industries makes a freewheel with two gears on it: 16/18 or 17/19 tooth. you have to move the chain by hand.
I think that they suggest you don't use that for trials though. Yeah, like a 3 speed internal trials hub would be awesome. I wouldn't care about weight so much as it's on a street bike. I'm sure with the technology now days it's possible to make it reasonable in weight anyway.
Im not sure on the price, but there is an alternative to the new Hammerschmidt crankset.
Im pretty sure NC17 and someone else have done them too, think the gear change is somehow operated by a button at the centre of the drive side.
Think you change by pressing it with your ankle, which may be an issue, especialy with all the new fasionably spinny moves of street trials
Just a thought.....
Just get a mech, run a tiny bit of cable from the cable adjuster and use the adjuster, it should have enough adjust to switch one gear.
Or use a screwdriver and do up the stop screws to change gear.
Far more sensible than trying to use a tensioner to change gears anyway.
Or...just get a white industries eno trial....then whack the two cog outer on it?
It would work with the Tensile tensioner, would take about a minute to re adjust it properly to the secondary gear, wouldn't be too bad atall..
Edited by cai
if you ran a smaller sprocket next to your current sprocket and used a tryall/atomz/tensile tentionor, you could change the gears with minimal faffing, i've toyed with the idea a few times (biking 7 miles home on a trial bike ftl) but it'd be no good for your chainline and putting alot of hammer through the bent chain is probably bad, or if your lucky you can misalign the tentioner to sit the chain between the sprockets and you can free-coast, stamping on your pedals usually pulls the chain back onto the sprocket (my f**ked up old rohloff could do this, and 6 times out of 10, work every time...) (Y)
