2010 Stocktake
Mark W
New year, new bike, new pics of all 3!
(EDIT: Weights: BMX 9.8kg [now 9.5kg], 24 9.8kg, Zoo 8.5kg)
Frame and Forks
- Frame: Lynx Long
- Forks: Trialtech
Wheels
- Front hub: Viz Light
- Rear hub: Echo TR Screw On
- Snail cam: TR snail cams
- Front rim: Trialtech SL
- Rear rim: Trialtech SL
- Spokes: Sapim
- Wheelbuilds: Mark
- Rim tape: Tarty Special
- Inner tube (front): Maxxis Ultralight
- Inner tube (rear): Maxxis Welterweight
- Front tyre: Try-All
- Rear tyre: Monty
Brakes
- Front brake: Magura Louise
- Rear brake: Hope Mono Trial
- Rear brake lever: Hope Tech
Drivetrain
- Cranks: Try-All ISIS 175mm
- Freewheel: Echo SL 18t
- Chain: Trialtech Z610 HX
- Rear Sprocket: Echo TR Screw On, 12T
- Pedals: Trialtech MG-1
- Bottom bracket: FSA Ti 68x113
- Bashring: Trialtech Ti
Steering
- Headset: Cane Creek
- Stem: Try-All Pole
- Grips: Atomz
- Handlebars: Try-All Carbon
Frame and Forks
- Frame: Echo Urban
- Forks: Atomz
Wheels
- Front rim: Echo TR
- Front hub: TR
- Rear rim: TR
- Wheelbuilds: Ali
- Rim tape: Echo
- Inner tube (front): Kenda
- Inner tube (rear): Kenda
- Front tyre: Maxxis Holy Roller 24x2.4
- Rear tyre: Maxxis Holy Roller 24x2.4
Brakes
- Rear brake: HS33 (when it's on, which it hasn't been much)
Drivetrain
- Cranks: Trialtech ISIS 175mm
- Freewheel: Tensile 96 18t
- Rear Sprocket: Echo TR Screw On, 13T
- Bottom bracket: FSA Ti 68x128
- Bashring: I don't make mistakes
Steering
- Headset: Echo SL
- Stem: Onza PZ31 85x20
- Grips: Rockman
- Handlebars: Trialtech High Rise
Seating
- Seat: Federal
- Post: Premium
- Clamp: Inspired
Frame and Forks
- Frame: WeThePeople AtoB
- Forks: WeThePeople Helium
Wheels
- Front hub: WTP Supreme
- Rear hub: KHE Geisha Light
- Front rim: Odyssey 7KA
- Rear rim: Alienation
- Spokes: Sapim
- Wheelbuilds: Mark
- Rim tape: Kink
- Inner tube (front): Maxxis Welterweight
- Front tyre: Ody Aitken 2.25
- Rear tyre: Ody Path 2.1
Drivetrain
- Cranks: Profile 175mm
- Sprocket: Tree 25t
- Chain: Z510 HX
- Pedals: Fly
- Bottom bracket: Profile Mid, ti
Steering
- Headset: FSA Impact
- Stem: Profile
- Grips: Yoshida
- Handlebars: WeThePeople Mad Max
Seating
- Seat: Eclat Gonzo
- Post: Eclat
- Clamp: Fly
EDITEDITEDITEDITEDITEDITEDITEDITEDITEDITEDITEDITEDITEDITEDITEDITEDITEDITEDITEDIT
New frame, Fit Hawk V2 - shortened the rear end with the use of an Ali and a grinder (then a file...).
Bikes look sweet. And i'm lovin the inspired sticker on the echo.
Do the trialtech high risers feel the same as normal trialtech bars but taller? as they have the same up and back sweep. If so I might have to invest!
They sorta feel the same, but it's hard to describe 'cos they're pretty rolled back on my 24 so they feel more 'streety' rather than more trialsy like Trialtech Sports do when they're rolled forward in a normal trials way. They do feel reasonably similar though, it's basically just the bit between each bend that's changed, rather than from bend to tip.
Ashamed of those profiles.
All looks nice though. Would have thought you would have a brake on the BMX though.
They were free and they work really well - not really much not to like about them...
is that one of the splined tree sprockets, if so how good are they as they use a interesting fitting system?
It's awesome. Had a 25t, moved up to 28t, now back down to 25t - they've all been fine. Really nice and solid, plus it's meant I snap a lot less chains 'cos my chainline is spot on now whereas normally it'd be a fair way off. Bueno.
What Echo is this?
I love the BMX the other 2 well their trials related so meh.
That kinda depends by what you mean by 'riding it around normally' - I'm used to either no seat (mod) or a low seat (BMX), so I just leave it low. I never really tweak the height of any of my seats just because I don't really use them much, other than to feel where my bike is when I'm doing tricks and stuff. I hate sitting down and pedalling so I never really do it, so it's not really an issue.
Street wise though it's really nice. Can do 'trials' on it if you want, but it's also nice for doing 180 bunnyhops up stairs, general spins, manuals, manuals to 180, brakeless nose pivoty things, half cabs, etc. - it's just really nice with that bar and stem setup 'cos it makes it feel shorter and higher which is pretty ideal for BMXy manoeuvres.
Yeah, if this Echo had horizontal dropouts it'd be peeerfect. If you get a longer Pivotal post (they come up to 330mm length, which in imperial measurements is about 4 miles), you could run a nicer seat that you can raise up without it being too heavy. Other than that, it's ideal really. Kinda fun to just ride from spot to spot too. I'm running 18:13 so it's a bit better for getting speed up and doing rollbacks, and it means it's also a pretty ideal 'riding around town' gear too. Can nip in and out of traffic easily, etc. It's just good!
Not developed wobble yet?
I keep them tight and don't take them on and off much.
Any particular reason you use a magura disc on the front and a hope on the back or is it just thats what you had available?
Precisely (Y) That front brake's been with me since the Atomz stock...
Mark, do me a favour if you don't mind bud, could you measure from the BB center to the top center of the headtube for me?
The WB, is it 1020mm on your bike?
I'm thinking a the wee bit longer chainstay on this frame would suit me down to the ground.
I'm liking the look of this frame more and more, was tempted when I got my skull.
