Tar On Disk Brakes?
matthew_coggan
i once convinced a guy to put lemonade on his brand new bb7 to bed it in. very funny. not very successful
+1 but with coke, funny to advise bu id never do it myelf lol.
tar on disks is a big no no, if it doesnt work very well, get a better one or set your one up better
Dont try to be a smartass
ride ur bike without the tar like everyone else does.
Mate you sond like a willy, How was i trying to be a "smartass" ?
Ryan knows what he is talking about. Put super glue on your rotor. and hold your lever in with an elastic band then leave it over night and it will be the best brake in the world the day after.
Am not a retard i no that wont work, but for me a very thin bit of tar on my rear rim helps my braking. I cant belive no one else uses it.
I do... Well since 2 days ago anyways... My new trials buddy had some and I was like what the hell?!! Tar??? How could that possibly work...
And sure enough I'm now going to get some as it helps tonnes. ^_^
Your right it does work... until your rim gets wet. It's just as easy to put a grind on a rim though, which is far more effective, providing you have access to a grinder.
I will agree soon as water gets on it, it wears off super quick, but i carry a spare piece with me so i can put more on.
Look what i fount, on tarty bikes.
Monty Brake Spray
£5.00 x 2
Description
- Great little brake-improving invention from the original BikeTrials brand Monty!
- We've nicknamed this stuff 'Tar in a Can', and it's really useful to improve your brake instantly!
- Brake spray is extremely easy to apply and works great in all conditions.
- The main thing to bear in mind is that you only need a light coating - too much will make your brake worse!
- Simply dry/clean your rim off with a clean tissue or cloth, lift the wheel off the ground and spin it. While its spinning, spray a light coating on the braking surface, and then scrub it round with your brake pads. Wait a few minutes for it to dry and you're away!
- Sold in an easy-to-use single aerosol can.
