Nitromorse
Mockett
Do wear rubber gloves.
Do paint it on fairly thickly, and leave it for a while, 10 mins. Depending on the paint it can just literally peeeeel off and you just wipe it down.
Do not touch the stuff.
Do wash it off straight away. You'll know when it's on you. Not immediately, though.
I might add, latex gloves can be disintegrated by it, so those won't do.
Edited by Revolver
Wire wool will be useful in getting paint out of welds and other little fiddly bits
Also, do it in a well ventilated area, The stuff stinks and I'm guessing the fumes aren't very good for you either
It's funny you should say that, I did my zenith at work in my signal box which is really small so I opened all the windows to get rid of the fumes but there was no smell at all!
It only burns if it's reacting with paint, if it's "just" the Nitromors it's not so bad. I stripped my frame on a bit of cardboard in our living room bare-handed and it was fine. Bit of a heady aroma but you get used to it pretty quickly. A nice wire brush or some wire wool will also do the trick for getting the paint off when it's time to get out of there...
It's been about 3 years since I used it, It was probably the paint it was burning that made the smell as opposed to the actual nitromors, but it absolutely stunk when I used it >.<
