My 2011 Rockman Slate 3
netto
I just finished installing my spade 3 fork. I even sprayed my stem black to make the bike look a little neater :D
Specs :
Frame : 2011 Rockman Slate 3
Fork : 2011 Rockman Spade 3
Headset : 2011 Neon Bow
Stem : Rockman 125x25 forged
Bar : Rockman Carbon
Bottom Bracket : Reset Titanium with Echo SL bolts
Cranks : Rockman Rockarms
Pedals : Modified Wellgo MG-1 with titanium axle
Freewheel : 2011 Echo Ti
Front wheel : Rockman Rockrim / 2011 Bub disc hub laced with DT Revolution
Rear wheel : Rockman Rockrim / Rockman 135mm rear hub laced with DT Revoluton
Tires : Try-All Shift / Sticky Light
Front brake : 2011 Magura Marta Magnesium SL with Carbon Blade and 180mm RockRotor v2
Rear brake : RB Designs HS-33 with 2011 Phatpads
Cross post from Richmond trials (Discussion is about hs-33 forks, but the changes still apply) :
Rockman has made some design changes to the Spade forks for 2011. We've just received the 4bolt versions, and they look amazing. As you can see in the picture, the taper for the crown race is very gradual (you can barely see it!). The dropouts are also a little smaller than the previous iteration.
The steerer is also thicker near the crown area. There is a lot of material there.
Here are some pics of the matching tapered forks supplied with the grey Slate 3 tapered frame.
How do you find rear Sticky Light? Compare it to regular Sticky or some Conti kevlar ones.
I like them a lot. It's more stable for me than the continental rubberqueen/trialsqueen. The compound might be slightly less grippy, but it's certainly more usable on angled and cambered obstacles. Overall, it's a more usable tire for me.
Edited by netto
