Get Rid Of Mag's For Vee's?
LROB87
just recently decided to get back into this and the bike came with a rear mag, thinking about the old days nostalgia made me get a front one too, then i released what a pain in the arse they are and how crap the evo adapters are as i only have canti mounts and the rear didnt even have an evo mount on it just a mag booster wtf? anyone got any perfect setup tips or should i say goodbye to em and get some avid 7's or something? a rear disc is out of the question as i have a old giant hawyes with no disc mounts surprise surprise lol
Strange to see so many recommendations specifying every individual component ( except noodles - unsung heroes ) but omitting the most critical variable - the rim(s). LROB87 , whatcha' rollin'on ?
For me it's a lightly ground Onza Ronnie ,
Avid SD7 levers,
XT arms ( really impressed , look great too ! )
Noname booster that I've been running since like the early 90's B)
Trialtech pads
with a linear slick cable , though I might consult with my LBS about some SP51 at Mr.C's recommendation . Not too sure about optimal setting of the speed dial adjuster , between squishy but powerful or sharp but less forceful I kinda leave 'em in the middle .
vee's ***. these levers (well worth buying the pair if you want to use a front cable brake later too...best cable disk brake going....). i found SD7 callipers to be nice at first but prone to alot of wobble when they wear, i have a set of bikehut vee calipers there very well made, not as nice to look at but there far more sturdy than the sd7's i'm using atm. don't skimp on the cable but don't get suckered into buying silly expensive posh ones, just a new inner wire every few months (i usually replace it every 4 months) i think i'm using this cable atm, but linear slick cables are prety mint too. i really rate the tnn lgv pads, they're the best pads i've used so far...
levers - £16
caliper - £16.95
cable - 2.99 / £6.99
pads - £30
that all floats in at under £70, winner
Listen to him! I ran pretty much that set up when I had a vee, but I ran Heatsink Coust pads and they are really good. Reds are worth a go too.
Of the brake side of things its worth getting SD7 over 5 as the limit stop screw are allen keys on the 7 and the 5 are philips and are a bit cheese like!!
The clarke cables will stretch loads, using one at the min and its not the bes. After ogre's advice Ill be getting a few off CRC in the morning.
Edited by Matthew_Gibson
Avid SD7 levers,
Trialtech pads
Let me know how that goes, cos I can't find them.
