26" Echo Sl - Updated With Brake Pics And Weight
Franksx2005
I have not done a bike pic thread for a while so here is my latest ride thanks to Jack Meek.
Weight is 8.87 with loads to be lost
Frame and Forks
- Frame: Echo SL
- Forks: Trialtech 4 bolt
Wheels
- Front hub: Echo TR non-Disc
- Rear hub: Echo TR 135mm
- Front rim: Trialtech SL Front
- Rear rim: Echo TR Rear
- Front tyre: Try-All Shift
- Rear tyre: Try-All Sticky Light
Brakes
- Front brake: 05 Magura HS33 herzblut Edition with CNC blades
- Rear brake: 05 Magura HS33 herzblut Edition with CNC blades
- Brake pads: Tnn Bealy rear and Phat pad Front
- Brake clamps: Echo Tr Rear And Tnn Front with ti bolts
Drivetrain
- Cranks: Try-All ISIS 175mm
- Freewheel: Echo SL 108 18T
- Chain: KMC Z610HX
- Rear Sprocket: Trialtech Screw-On 15T
- Pedals: Echo TR
- Bottom bracket: Echo Urban ISIS
- Bashring: Trialtech Titanium
Steering
- Headset: Echo SL
- Stem: Try-All 3D 127mm 30*- Grips: Echo Rubber
- Handlebars: Try-All Karbon
Brakeless photos
Edited by Franksx2005
Renthal grips? I love it for my trial motorbike, but never try to fit in my bike...
Maybe you need 2 pairs of grips because i think that you only use the thin one, because the grip that fits in gas ones in motorbikes are bigger...
