Quick Diy Question Regarding A Door.
JT!
Door in our house is slightly too high. The top scrapes on the door frame at the top and the latch thing is just a few millimeters higher than the hole. Problem is if I take the door off and move it down a tiny but, I know that when I screw the hinges back in, the new screw holes are going to be a couple of mill away from the old holes and that's going to cause problems on the cheap wood. Any suggestions?
Move the latch and sand the top of the door off? What sort of latch? Picture of the door would help muchly!
I'd do it this way.
If it was hung upside down it'd be inches off, not millimetres, and having it not work as a door for a season isnt really right.
Moving the latch is probably going to be much more complicated and the door is sitting way to high.
Might sound a tad silly, but has the door been hung the upside down?
Nope.
Wait for the warmer weather and the doorframe to expand.
It does the same thing all year round.
Plug the old screw holes with wood glue and matchsticks, seriously this works.
Sounds like a plan!
Fixed. It needed to come down 6-7mm so the old holes wren't actually a problem. Thanks everyone! f**king cheap shitty house with cheap shitty doors.
Now because the mother in law and the wife will take 10 years to get used to it shutting properly every time they shut the door it sounds like it's about to rip out the frame.
  • Like 1
