24" Ashton Ed Tongue . . Nope, Not An Inspired :)
iwannaleeson!
Morning,
Went out on the first ride last night and it's definately more my sort of thing than my 26" Gu Typhoon. Thought i'd share!
Frame - Ed Tongue (old skool!)
Fork - Gu
Front wheel - Dee Vee rim on American Classic
Rear wheel - Dee Vee rim on Chris King Singlespeed
Tyres - Tioga street
Cranks - Middleburn with bash
Pedals - Onza Hognesium
Front Brake - Bb7 with scott lever
Rear Brake - Deore with Xtr Lever
Grips - Odi X trainer
Bars - Trial Tech Riser
Stem - System X
Headset - FSA Orbit
Saddle + Post - Gusset
post-4968-0-05855400-1340702610_thumb.jp
post-4968-0-88538500-1340702657_thumb.jp
post-4968-0-29651200-1340702704_thumb.jp
Thanks for looking
  • Like 1
Couldn't agree with the above comments on change of forks.
Why not?
I don't think the ZOO! forks particularly go that well...They do kind'a look like fatties/ashtons but its just not the same having Deng on there. If you were to pick up some Pasheys, Fatties or Ashtons then they might go a little better. Might have a longer steerer too which would help the way it rides.
  • Like 1
Why not?
Sorry Ross, my bad with the typo. I was supposed to say, couldn't agree MORE with the above comments about changing the Zoo forks to something like Trialtech and the maximum height of stem stackers to improve the ride.
Looks amazing. Better than it did when Dan had it (sorry! :$ )
I think having straight blade forks, smooth rims and all black components make the bike. Love the Vee setup. Much lower profile than Evo mounts with a mag.
Edited by Echo Lite 09
The maximum height? Whats that?
From personal experience and in my opinion, with that bar and stem set up, an extra 25mm of stackers would suffice.
This, there is such a thing as too high, 20 odd mm of spacers would be fine on that unless you're 6ft 7".
Edited by LEON
Cheers for all the comments guys.
Definitely rides how I want it to! :)
In regards to the forks. . I may look to change them at a later date as they came straight of the GU, but for now seem to ride ok.
Also stem height is limited by my steerer length at the moment which I thought might be a bit low but again, rides spot on so not sure if I would want to change it.
well that's what happens when your on a budget and don't have mummy and daddy to pay for everything
  • Like 1
I like it.. I have always been a fan of the edd tongue frames.
Its different! Which is good. Inspireds are too main stream besides owning a inspired is like having a clit every c u n t has got one lol
Edited by Andeee
oooh you fickle b*****d lol. I went from this very frame to an inspired. wish I had a clit though, I'd never get bored
My mummy and daddy dont pay a thing for my riding. Hence my current situation, having no bike as I cant afford to replace broken components.
Looool
Please look after this bike by the way.
What people say about it "snapping" is very true. Ive had two. The first one cracked at the seat tube first. Got that bit welded, then it cracked at the head tube and got that welded... After that it wasnt the same and because it wasnt heat treated after the welds the cracks kept reforming.
The one I have just now is cracked at the head tube : At the weekend in the horrible weather I decided to file the dropouts so I dont have to run a tensioner. Best idea ever!
Heres mine http://www.trials-forum.co.uk/topic/165529-clean/page__p__2301599__hl__+brakeless#entry2301599
