Hook Attempt
isitafox
Spotted a wall down Salford Quays this morning that looked alright for practicing hooks on so I had a go. Don't even know if I was doing it right or not so I'm well open to criticism/pointers, also it was the first time I've ever attempted them and without anyone to ask I just had to go with what I thought was the correct technique.
Anyway
  • Like 1
get your weight further forwards, you don't need to go any higher (I always aim to get my front wheel just over the top of the wall) This way, all of the upwards momentum from the hop carries on up and on top of the wall. If you your weight is forwards, you hardly have to do anything in the second stage.
so yeah, weight further forwards is the key, then you'll be getting manuals out of it.
  • Like 1
Your going far to high, not really a hook. Sorry for sounding like a fanny!
You need to find a more vertical wall and bend your legs more while pushing the bike into the wall.
Let your hips go forwards slightly to help getting the weight over the front and forwards
Good effort though, it's good to practice getting up the wall but don't do that to much other wise you will find it hard to get the correct hooking technique as you will resort to your bad habit technique.
what do you mean by hes going to high ? just wondering.. i am also trying to learn hooks
I could get up to 2 on it just thought it looked a decentish height to have a play.
Will try and find something a bit more suitable near home but I achieved what I set out to which was get some advice about if I was going about it right or not.
By going high it's basically transforming the linear force into a trying to rip the forks off using a 90 degree wedge
By landing lower your pushing the bike directly into the front of the wall making it easy to keep the moment going forwards
