help! :(
m.stone
Got a zoo pitbull, got a tensile 18 teeth freewheel on front and a 15t on the rear,
chain meets up but the freewheel is stiff, so put an onza tensioner on it.
found out my drop out was bent so replaced that.
and still the chain keeps coming off.
the chain is a kmc k4e?
Anyone know any reason for this?
Thanks
When you say the chain's coming off do you mean actually coming off the drivetrain completely or just skipping?
Coming off the rear cog mate
looks like you need to move the rear sprocket closer to the dropout (away from the center of the hub) to me or use a narrower axle bb if you can clearance wise, could just be the pics though.....
I was thinking this as there is two big spacers and one small just swap small one to the other side, trip to get some tools then for me :/ lol
I seen one simmilar before. I put the rear cog to the outside edge and bent the Dmr steel tensioner out straight so it would line up Propper.
You may well struggle to straighten out that alloy onza tensioner.
So a shorter bb or Dmr tensioner will sort out your chain line. But you can only have he shorter bb if your cranks are a long way from your chain and seat stays ( frame)
Just curious, when you roll around, what part does the freewheeling? The front freewheel or the rear hub?
Rear hub mate
You're using a freehub and ffw wtf?
Yes I haven't had anyway of changing it atm, I brought I new rear wheel with hope freehub, as my last wheel was a welded deore hub so was using ffw
