I Wanna Put A Tough Coating On An Alloy Rotor
Ali C
I might have the oppertunity to have an alloy rotor made to my design by Wad.
I have designed this (Wad hasnt seen it yet so I dont know if the final one will look like this)
Now I realise that an untreated alloy rotor wont be much good and I dont wanna change pads.
I have seen that Stans (of no tubes fame) rotors have a thin steel coating on the braking surface, I was wondering if anyone on here knows how this is done, or know of any other ways of getting a tough coating applied?
sorry to sound sarcastic, but give them a call
0) 1282 851200
they are uber helpful (well have been to me) and will tell you straight up.
or email
info@hopetechnology.com
thats your best way
they make custom sized hope rotors for people so you should see what they say
£40 odd quid for a custom rotor if your Mr Joe Bloggs but if your in the trade ali im sure you can get it at cost like i have done with the 2/3 of mine i had made. they dont cost too much over a normal priced rotor really.
if you have any problems getting it made and getting it at cost i will order you one from my work and sell you it at trade price? you can even have your name etched into it how kools that............. :turned:
Waynio......................
allo
I will probably leave it as it is and just run it with normal pads for comps only.
I am gonna design more rotors (its fun :turned: ) andI have been told I can have curves in the design :) (although I still recken its the most buitifull rotor ever)
allo
I am gonna design more rotors (its fun :) ) andI have been told I can have curves in the design :P (although I still recken its the most buitifull rotor ever)
Wayyy, that's better :turned:, batman would be proud as it is though.
Phil.
ali you probly dont want to have all them sharpe corners, stress is just gonna build up there, put small rads on, as for being coated you could get coated with a process called tennifer (spelling)? which is what the do to forming tools to make them very hard, but im not to sure if it can be done on alu.
you could try as a start to get it heat treated and try that as i dont think your gonna get the same heat build up with trials as to down hill
and i dont see why they can made one from steal as you would use the same cutting tools just a much lower cutting speed :turned:
looks kool though and good luck with it
Edited by dave33
In nearly all cases they are stainless steel.
If your not assed about the weight ali you should try some beasty iron discs, get an old motorbike disc brake chop one side of the disc off and surface grind it down and drill the holes in the relavent places, that would be a beast, but may rust rather quickly.
Phil.
just reading a disc packet today and yes it was stainless steel. that was an aztec rotor (Y)
cant realy surface grind rotors as they tent to have magnetic tables thus pulling the disc flat and after you grid and take it off the bed it springs back to its original shape and you have high and lo spots, unless its perfectly true and flat :-
