Bleeding Maggy's With Water Not Oil
montyrider
today i jus bled my rear maggy with water as it has been driving me crazy for ages as it was sticky and horrible no matter how many times i bled it with oil! and now its amazing! it is so snappy and the lever return is quick, its jus perfect better then anything i've ever used it feels jus like a disc brake. i bled it with bottled water as thought that would a better idea...
but can anyone tell me is their anything wrong with me using water? :unsure:
i met some guy who's done the same and his brake is amazing aswell seems much better than using oil! :D
yeh mate your only problem is freezing and apparently it can reck your seals cos when it freezez obviously it expands and makes the seals bigger therefore not fitting properly
steve
Water is fine, I sometimes leave mine outside over night and it doesn't freeze and I couldn't be bothered using anti freeze. Oil gives it a really slow slugish feel which is horrible.
Bottled water is not going to make much difference to normal water really depending on where you live. You would be better of distilling the water in a pan first so there is less air in it, won't make much difference though.
The only down side is that your warranty doesn't cover it being filled with water.
steve
Nein. 'cos there's room between your pads and your rim, when the water expands it just moves the pads out a little. It doesn't expand a huge amount, so it won't squeeze hard enough to push the pads against the rim, force against the booster and then rape your seals (Y)
you won't wreck your seals if freezing is a problem use some anti freeze
use the seach for more topics like this one.
Yeah, there's another thread with some good info in it somewhere :)
i was gonna do that but thought i'd check it's alright to use anti freeze first incase would damaged my seals or anything of the sort!
It's all good. I've got a pretty strong antifreeze:water ratio in mine, and it's been fine *touches wood* It doesn't harm the seals, so it's all good.
I was waiting for that.
But I swear it's been below that some nights when my bikes been in't garage.
Never frozen :rolleyes:B)
Unless your using the brakes all night, then how can you tell if it's frozen or not? Chances are that if the temp went significantly below 0 the water would have frozen, by the time you got up and went to the bike, it probobly would have melted....... It makes no differance anyway if it freezes it freezes and as mark said suually the pads will move due to the expansion rather than the seals..
