Bodges!
Alun Goch
OK guys, tell us all about you'r greatest bodges, pics would be nice too!
Only rule, no maggie TPA's, to common! Unless it's something special
Anyway, heres my attempts;
clickyboo 1
I duck taped a V brake lever blade to my maggie lever for more legerage when I had to use some koolstops for a while. Did give more power, but I suppose it is abit dodgy!
And...
clickyboo 2
Overall, a very dodgy bike. Little money meant I skimped on parts. The bottom bracket and cranks I took off my old Y-frame sus bike, a few years old back then, and where impossible to stop wobbling!
The frame and forks I bought for £70 off a mate, and I bought a headset, the only other thing I needed for £12.99.
Had some amazing times on this though, last summer was amazing at our forest.
A lot of things have broken by now, but the frame, headset lol, bar and stem are sound, anyone interested in them make me an offer. I was going to build it up myself as it's a decent frame, but unfortunately £notenough£.
clickyboo 3
Chain tensioner made from a cotton reel, short length of hosepipe, copper wire and cable ties!
The seatpost I had was too small for the frame, so I ground a piece of aluminium tupe that nearly fitted a fraction smaller, stuck that in the frame with a stretched quick release off a micro-scooters handlebars, and found a clamp to squeeze the top of the tube to the seatpost! (had to cut some slits in for the tube to bend)
I also ground (yes I like grinders!) the outer chainring round! Running single speed by the way.
And the suspention had about 12 washers within the forks on EACH side, because when it bottomed out, which was often, the tire hit the underside of it!!
Show me what you've got!
Alun
The pin that holds the mech cage in place fell out so i put a lolly pop stick through it instead. And that was a good 5 rides ago i think i need a new one!
My front wheel is a 36 hole D321 on a 32 hole hub, and the rim has two drill holes going through just one wall. Built last summer with odd spokes only buckled now. Survived the comp at fort bill and many other rides.
Alex
haha mike that must be one stiff ass brake.
i heard you bodged your willy kyle.....is it true?
please tell me its not.
i heard it happened when you shaved your pubes but cut ur willy off as well :o:P
haha.
many a mech hanger has been bodged, all sorts, but that was back in the day. i run a sweet bike now :P
it is actually stif as fook, just likes to move sideways occasionally ... hehe
the headset is pretty bodged too bearings don't fit properly in the bottom cup, so there is a gap of about 3mm between fork crown race and headset cup....yummy
Edited by leedstrials
I ain't got any pictures, but years ago I once constructed a DH-style chain guide out of the old knackered cage off a wellgo beartrap-type pedal and a bunch of cable ties.
Worked damned well, too.
Best bodge I've ever seen goes to a mate who totalled the BB and cranks on his bmx off some doubles...so he extracted the remains somehow, shoved a twig through the gaping hole, and proceeded to do one-footers, no-handers, and any combination of the above off the same 6' double.
Said twig snapped when he rode off kerb later in the day.
Nutcase.
The pad i use to stop my mech banging against the frame fell out on a ride, so i went into the local corner shop, asked the dude for a strip of sellotape and found a bit of foam on the street to use as another pad.
Worked awesome.
I have a washer bodged with a thin bit of metal i cut down as i could find a thin enough washer.
Using a 2 bolt maggie booster on a 4 bolt frame.
S'about it methinks.
I bought an apollo outrage from a local charity store (long story) for £40. I kept it in great working condition for 3 years without spending a penny overcoming the following:
Bent/snapped bars : spares :)
Front derraileur fooked : Took it off with the chain rings and made it single front cog
rear derraileur fooked : Kept the mech on but used a very long bolt in the low range to change gears (obviously when stopped) :P
Paint job : spare black spray paint + tippex ;)
For trials, when I was using VP pedals the cage bolts snapped and I used paperclips to hold them on.
When my shoes fell apart, I used duck tape :D :D
Nutcase.
Sorry, sounds like your mates telling porkies to me. Withstands a 6" double then breaks on a kerb? hmmm...
Great bodges guys, very creative! Keep 'em coming
Alun
ONce me and me mate (Krisboats) Bodged my mech up to the limmit ... we had drilled it ... bent it .... and stuffed allen keys around it to tension it, workerd a treat.
Overall after we din't have any ideas left kris was playing with it with a allen key and used it as a little bit of cable.
Was cool B)
Alun
Nah I was there, we got the crank/breakage and the jumping with twig on video as well. Didn't get the twig breakage off a kerb though as we were riding home and didn't have the camera out (hardly worth videoing anyway). Obviously said twig had been weakened by a madman doing jumps on it, and that kerb was the last straw...'twas funny as fook anyhow.
I'll have a look to see if I can find a copy of the vid (just for the stack footage if nothing else), but I think the only person who's got a copy (it's on VHS) is a guy who I'm no longer mates with.
OK, I believe you, sorry it just sounded abit 'as if' to me. Your mate must vave some guts too!
Alun
Hows this for a bodge/mod!!!?
The story is.....
I bought some second hand fattys, go to build bike and steeres too damm short, by loads!
Humm my initial thought was to sell them and try and get another set. I really didn't want to do that as these forks were mint and theres not too many of them around.
My dad had some crazy idea that he could extend the steere tube :ermm:
As he's an engineer I took him a little more serious.
So we measured how much it was short by (16mm) and he made a steel round lump, lathed the bottom down so it would fit inside the steere, then drilled the middle out the same as the steere, welded it all together and smoothed/filed it all down :)
Now I have one mint perfect length steere :D
IPB Image
IPB Image
He also lathed my bash down the other day too
IPB Image
One pretty big bodge, but done pretty damm nicely!!
