Rockman Bikes News
Bigman
This thread shall be used to post pictures of any new Rockman Products, I will keep it updated as much as possible!
Kortz Frame (As ridden by Myself):
Introducing our new competition spec 26” frame, weighing in at only 1.55kg. The frame is constructed from high quality triple butted tubes 6066Alu on the top and down tubes to bring the weight down, and the other tubes from 6061Alu for maximum strength.
Designed to clear 18:15 gear ratio.
CNC 4-Bolt Magura mounts with booster that seats into the frame for a stiffer brake feel.
CNC machined chainstay yoke.
On this frame there is a simple built-in chain tensioner on the rear CNC drop out... An idea which came from BMX racing which have been in use for about 6 years.
We have been working closely with Bigman on this frame and would like to thank him for his inputs and for sorting out the colours for the art work on this frame.
Sand blasted, then 3 tone anodized finished green and orange for lightweight.
Geometry:
1093mm wheelbase
+60mm BB
71.5deg Headangle
380mm Chainstays
Available in Green and Orange
<img src="http://www.rockmanbikes.com/img/IMG_2478.jpg" border="0" class="linked-image" />
Slate 26inch Frame (As Ridden by Andrew Walker begin_of_the_skype_highlighting     end_of_the_skype_highlighting)
One of the latest frames from Rock Man Bikes, the new Slate 26".
- Cut out hole in the head tube save weight
- Aluminium 6061-T6 .
- CNC machined chainstay yoke is hollowed out at the rear and to the sides.
- Designed to clear 18T recommend 18:15 gear ratio with 175mm cranks.
- Head tube is 110mm long.
- Neat and simple CNC machined horizontal dropouts.
- The frame needs a snail chain tensioner to run.
- CNC 4-Bolt Magura mounts
- Double butted Top and Down tubing keeps the weight to a minimum, but strong downtube.
- 135mm rear dropout spacing.
- sand blasted and then anodised finished blue and grey for lightweight.finish.
- Weight:1.59kg
Geometry
Wheelbase:1080mm (with 35mm offset Fork) 1085 - 1090 with 40/45mm rake fork
Chainstay:380mm
BB Rise:+45mm
Headtube angle:71.5
<img src="http://www.rockmanbikes.com/img/b_bslate7.jpg" border="0" class="linked-image" />
<img src="http://www.rockmanbikes.com/img/b_pslate5.jpg" border="0" class="linked-image" />
Aurem 20inch dual disc frame (As ridden by Bjorn Levin)
Geometry:
1020mm Wheelbase
350mm Chainstays
+75mm Bottom Bracket
71.5degree head angle
Disc Only
Available in blue and black.
Pictures:
<img src="http://www.rockmanbikes.com/img/b_auremcombo2.jpg" border="0" class="linked-image" />
<img src="http://www.rockmanbikes.com/img/b_auremcombo6.jpg" border="0" class="linked-image" />
Price is to be around £390 - 400
BUB front Disc hub:
10mm hollow 7075 T6 aluminum axle
Fully 7050 T6 aluminum CNC machined hub shell
6 bolt International standard pattern
2 Sealed bearings
Colors: Anodised Black or gray
Available in 28 or 32 holes
Weight 135g (without bolts) (155g with bolts)
<img src="http://www.rockmanbikes.com/img/s_bubfrontdisc1.jpg" border="0" class="linked-image" />
<img src="http://www.rockmanbikes.com/img/s_bubfrontdisc2.jpg" border="0" class="linked-image" />
BUB rear disc hub, 116mm
10mm hollow 7075 T6 aluminum Axle
CNC machined 7050 T6 aluminum hub shell
2 Sealed bearings
Threaded pitch size of 1.37X24tpi
Available in 32 holes
Weight 190g (without bolts)
<img src="http://www.rockmanbikes.com/img/s_bubreardisc1.jpg" border="0" class="linked-image" />
<img src="http://www.rockmanbikes.com/img/s_bubreardisc4.jpg" border="0" class="linked-image" />
BUB rear non-Disc
2 Sealed bearings
Weight 175g (without bolts) (195g with bolts)
<img src="http://www.rockmanbikes.com/img/s_bubrear1.jpg" border="0" class="linked-image" />
Updated Front non-disc hub:
Cleverly designed hub flanges remove weight while still maintaining strength.
Fully 7075 T6 aluminum CNC machined hub shell
2 Sealed bearings
Colors: Anodised Gray
Weight 63g (without bolts)
<img src="http://www.rockmanbikes.com/img/s_bubfront1.jpg" border="0" class="linked-image" />
Rockwheel, 72ep Freewheel:
72 Engagement 6 Pawls
Threaded pitch size 1.37 X 24tpi
Color: Black
Weight: 180g
<img src="http://www.rockmanbikes.com/img/s_rockwheel1.jpg" border="0" class="linked-image" />
Rockcams snailcams:
7075 T6 aluminum plate snail tensioners
Weight: 7g
<img src="http://www.rockmanbikes.com/img/s_rockcam1.jpg" border="0" class="linked-image" />
UPDATE 3.8.09
New 20inch Maladie frame (As ridden by Kieren Whitefield)
Introducing our new rim brake 20" frame in Army green or Black.
- Aluminum 6061-T6
- CNC machined dropouts are spaced at 116mm
- CNC 4-Bolt Magura mounts with built in booster
- Rear brake mount spaced at 100
Geometry
Wheelbase: 1030mm
Chainstay Length: 363mm
BB Rise: +85mm
Head Angle: 71.5 degrees
Centre of BB shell to top Centre of head tube: 615mm
Weight: 1.55kg
<img src="http://www.rockmanbikes.com/img/aug09/IMG_0260s.jpg" border="0" class="linked-image" />
New Spade 26inch HS33 fork:
We wanted to built an ultimate fork, so this is what we came up with.
- 7005 T6 aluminium
- CNC machined dropouts with spade shaped cut out
- One piece steerer tube with extra thick bored section and offers a stiffer fork
- 4 bolt mounts on the rear of the fork, spaced at 91mm
- Integrated booster which helps to increase brake stiffness
- Available for 26" wheel bikes only
- Brushed silver finish
- Weight: 859g (with uncut 200mm steerer)
Geometry
- Axle to Crown length: 400mm
- Axle Offset: 35mm
<img src="http://www.rockmanbikes.com/img/aug09/IMG_0288s.jpg" border="0" class="linked-image" />
New Rockarm Cranks:
Introducing our new crank arms, forged from high quality 7075 aluminium
This cranks are 1st forged then CNC machined out.
-Length 160mm, 165mm, 175mm
-Threaded to accept a front freewheel sprocket
- Super light yet still stiff and strong enough for competition use
- Anodised matt silver finish
- Weight of 175mm is 435g
- Weight of 165mm is 425g
- Weight of 160mm is 418g
<img src="http://www.rockmanbikes.com/img/aug09/IMG_0311s.jpg" border="0" class="linked-image" />
New Rockbar Silver:
Increased backsweep and upsweep provide a much more comfortable wrist postion compared to conventional bars.
- 9 degree backsweep with 12 degree upsweep
- 31.8mm oversized clamp diameter for increased strength
- Good combination of strength and stiffness with 7075 aluminium alloy used throughout
- 730mm
- Weight: 295grams
<img src="http://www.rockmanbikes.com/img/aug09/IMG_0342s.jpg" border="0" class="linked-image" />
New Rockpad Blue CNC
Our best selling brake pads just got better Now it comes with CNC backing.
-Fitted to the brake cylinder using an O ring.
<img src="http://www.rockmanbikes.com/img/aug09/IMG_0341.jpg" border="0" class="linked-image" />
Thanks
Adam
Like the looks of it, I think more would sell if they came with magura mounts aswell though...
I'd imagine the price would be similar to the stock version, no ?
The mod frames are up on tartybikes now and listed at £390 so a good price in my oppinion.
Adam
  • 2 weeks later...
  • 2 weeks later...
Adam
I don't get it, really i don't. They don't appear to feature anything new or even remotely special. Yeah the headtube is drilled and the seatstays are pretty smart along with the bash join, but nothing worth £400. Where are Rockman getting their stuff produced? Or is that the key to the expense?
  • 3 weeks later...
I must say, I rather do like the look of 116mm hubs, might look in to getting one of them so i can run rear disc.
Also just wondering if anyone is running the freewheel, are you having any problems with yours, because mine has been skipping a lot as of late, just wondering if its a one off!
Edited by JohnyMilton
I am not running one of the freewheels so unfortunatly can not comment.
my freewheel seems fine...not had it very long though..
short stock looks mint- who's steveo?
Steveo is as far as i am aware one of Rockmans Test Riders.
Adam
Isn't the BB too high?
I saw these when i was looking for a new frame and the bb hight is what put me right off.
The angle the pictures were taken at does make the BB look very high, 75mm is fairly high, but i think the bike would feel awsome!
A quote from the guy who's bike it is:
my Rockman Aurem 8.3kg.
Rode it for a month now. After my XTP II.
This is the best bike ever !
Comparing the KOXXTP II with Rockman AUREM, i would say that the control is way too easy on the Aurem. The double wheel control is as stable as the Monty Kamel yet the rear wheel action is crazily responsive!! as if the front wheel isn't there when u r on rear wheel.
Overall : FAST, POWERFUL, extremely STABLE on 2 wheels or rear. What more can u ask for?
Adam
  • 2 weeks later...
Well i'd say the high BB is going to put more people off than it being a selling point. Got nothing against high bb frames, never ridden anything over +50 which is what i have now.
  • 2 weeks later...
