Front Brake Set Up
lewis.jackson
Mine is:
brake:Hope mono trial
rotor: Magura
rotor size:180mm
brake pad: standard hope ones
Not bad brake, did have a slight problem with it by contaminating the pads a few weeks ago but that was my fault so you can't blame the brake - still a great setup for a mod
This is on my Zona Zip.
Brake: hope mono trial 06
Rotor: hope mono trial
Rotor size: 160
Brake pad: hope
Wheel size: 20"
Pretty standard but it works really well and I am really impressed. I prefer the 06 lever to the 07s because the blade is squarer, which matches my rear magura, and I prefer the look of the old levers.
Brake: BikeHut cable disc
Rotor: BikeHut
Cable: Odysse linear slick
Lever: Avid AD3? (the one like the SD7s but without the speed dial adjustment.)
Rotor size: 180mm
Brake pad: standard
Wheel size: 24"
Works suprisingly well for like 35 quid (25 for the break, 5 for the cable and 5 for the lever off a mate), feels really really nice, better feel than a BB7 imo, but not as much all out bite, still holds well though. (Y)
Used to be:
Brake: Avid BB5
Rotor: Avid
Cable: Something standard
Lever: Avid SD5
Rotor size: 185mm
Brake pad: standard
Wheel size: 26"
Was good but not good enough so I upgraded the rotor to a 203mm Hayes and it works superbly - tyre usually breaks traction before the brake gives out (bearing in mind I'm 13 stone).
Am slightly scared that my forks are going to snap though - did snap a spoke the other day.
Edited by Jamie_Neal
Magura hs33 2004 lever
Magura black plastic hosing
Magura hs33 2004 slave cyclinders
Onza citrus pads on a light sharp grind.
Water bleed.
Best front brake ive used.
Better than my 180mm bb7 i used on my mod and this set up is on a stock.
Danny.
mine is the same as that just on a 26 wheel and 2006 magura it is well good.
was using a bb7 but it was to powerfull and cracked my forks :)
