Avid Bb7
carboy280
Hi peeps,
Which rotor would give better braking power on a front wheel (probably doesn't matter)
For a Avid BB7
160, 185 or 203
and which one would you recommend?
Also which one would fit on me front wheel... ive got Urbans with a Mono hub???
Cheers
Edited by carboy280
Hi peeps,
For a Avid BB7
160, 185 or 203
Cheers
Mono hub, isnt a disc hub. So no disc is compatible.
DOH! just saw that... (i dont actually have the bike yet... its in the post)
bummer, well looks like you going to have to get a disk hub then. If you do, then 180 will be fine or if you want a reallty vicous fornt brake that comes on striaght away with little modulation then get a 203.
185 will be fine dude. I ran 185 for over 2-3 years with no problems in power, 203 is a beast though.
You can get 2nd hand hope pretty cheap though. Brand new would be better though. Bearing as faultless. Had standerd one in for over 3 years with no problema and still going fine. Going to change them all In the newyear.
Go hope and you wont go wrong!
i believe 10inch is the largest too.
i find theres no points going for secound best stuff,get the biggest rotor avaliable for the brake ,then you wont be thinking (if you dont have the desired power) why didnt i get a bigger brake.
steve .
snap yer forks/spokes easyer.
Matx
That's a load of impractical advice. The chances of him snapping his fork and spokes are not much greater if he gets an 8" rotor, than if he goes for a 7". They're actually so small I'm surprised you're taking such a possibility into account.
Just get a 203mm rotor. Better too powerful than too weak.
