How To:
lewis.jackson
Just take your tyre off and carefully lift it out. If you put it under your pillow it might hatch.
Ahahah...
Yeah, Tomturd is right.
The bit thats further away from your hub will want the spokes tensioning (to pull it closer to the hub) and the opposite to the bits closer to the hub.
Where the wheel goes upwards, tighten a group of spokes on the opposite side.
Pairs are the triangle shape two spokes make, then a group two pairs. - Left, and right.
Make sense at all?
Just keep using quarter turns, and make sure it's a decent spoke key, don't go rounding off your nipples! :turned:
