Will This Work
scott21
I did this. I had my monty freewheel on my VIZ hub with some shimano cranks. Then I bought a 15T cog and echo cranks, took the freewheel off and put it on the crank :) That was on a stock bike, by the way, but I can't see it not working on a mod :)
should work but the thred on the free wheel will be reversed when you put it onto the cranks and might come loose when riding!!!
No it wont.
Freewheels are the same whether you use them on the front or the back, they're all on 1.37" right hand threads, so the only problem you might have is if your BB axle is too short to allow clearance for the freewheel on the front when you change cranks.
True
What's this reverse thread shit?
I had an eno, it was on the back, and it was on tight.
Supercycles took it off for me, and I put it on the front, where it was also tight.
It never came undone.
Exactly.
Can no-one see he was riding a t-vee.
So presuming its the freewheel off that?
To be honest don't use that freewheel.
I used mine from my t-bird (presuming similar cheap freewheel) and when i changing it to front it locked up after 20 minutes of riding.
did that once on my old t-pro.
i'd get a tensile free wheel (or something similar) with a reversed thred.
This is true you can get different threads on a tensile and if you couldn't then why on the box does it have if it is for front and rear!
