Deng Frame Improvement Thread
Jason222
Alright, so I just thought about this...
I like deng frames, but it seems that all of his frames have something that makes them just imperfect. I've gone through 4 frames in the last year. All have been chinese made, and 2 were deng. I find each has something about it that just plain out turns me off.
Echo control short 06:
Good features:
Excellent frame strength
Very stiff
Improvements:
375 mm chainstays are too short, should have been between 380-385.
Weight.
Geometry?
GU LE 08:
Good Features:
High bb height
Lightweight
Good tire clearence
Good TGS Geo
Improvements:
These frames are too flexy. The top and down tubes should be joined somewhere to improve stiffness. The rear end is also quite flexy, thicker tubes or a built in booster would be great.
They are also on the short side for a TGS/Comp style bike. The reach should be at least 5 mm longer, and head angle should be a bit sharper.
Feel free to post your deng bikes, and how you'd like them to be improved. Also feel free to argue with the improvements of others...
Edited by Jason222
I see that for the Echo, you've mentioned it is stiff but the weight could be improved upon.
Then for the GU you've said its lightweight, but too flexy.
You want a stiffer frame, you add material in critical areas, which increases weight.
Some people actually prefer a "softer" frame.
You can't have it all.
Edited by Trials Punk
You can't call geometry an imperfection cause its personal preference ?
Yeah, but geometry is usually based on how it's going to be ridden. So, the echo control short is meant to be a mixture of street and TGS. But the length is a little odd and the CS are too short.
all the comments on geometry are irrelevant as its a preference so he cant do a frame in every geo possible. the thread is pointless as it will go no where unless your planning on emailing this to deng him self.
No, but he does have quite a few already! Think of this thread as better in general, not better to the individual.
Yes, but the difference in weight is almost 400 grams. There is a point as which a frame could be strong, light, and stiff. Look at most of Koxx frames... Actually, the GU LE could have been much stiffer if the top and down tubes were joined...or if the tubes were welded together in a different way.
Edited by Jason222
they are stiff and light...but not really that strong :giggle:
Not really all that weak either. Quite strong for the weight actually. And quite a lot stronger than some of the more recent deng frames to be released (GU ST comes to mind).
That's a load of crap yes frames are designed with street,TGS,natural in mind but you cannot comment on there being an "imperfection" in the geometry because it doesn't suit you.
And you cannot say the chainstays are too short and its a weird length cause that's how YOU would want it (back to what i said on personal preference) I bet some people regard that frame as perfect for them due to their style or even their size/weight.
So geometry cannot be classed as an imperfection unless something is drasticly wrong which makes it hard for it to be ridden for it's purpose.
Yes, thats 400grams more material, which equals a stiffer frame if that 400grams is put in the right places.
To be honest, I think the GU is meant to be a lightweight alternative to other frames in their range, also note that the GU has a curved downtube, possibly for clearence which will reduce stiffness.
I'm not really up on all the different frames availble for trials these days, but I'm guessing the control is more for street/natural, whilst the GU is aimed more at natural and dare I say it "TGS".
Same here. All of them are missing something.
I think it's the looks. A Deng frame is just differently shaped tubes welded together. A Koxx is the same but with added great paint jobs.
I agree with you, Deng frames was stronger, but in the last years they are weaker...isn`t only the weight, because the new CZAR, weights 2kg and is a lot weaker, I see a lot broken...
You are wrong, because if I sell you a frame with the geometry of a MTB you would want to kill me because the geometry don´t suit trials, but I sell you a "trials frame"...
the frame have to be designed for suit some styles and riders, but deng in the last years do frames with almost the same geo
(echo control 09 - 1090wb +30bb 380cs ----- czar 07 - 1095wb + 30bb 385cs ----- zoo pitbull 09 - 1085wb +30bb 380cs --- adamant a1 07 - 1095wb +30bb 375cs) so if you se they are very similar, except the Gu ( 1085wb +60bb 375cs) so you are buying almost the same frame of deng,
there is almost no variety, and those frames are weaker, except gu and adamant (i don´t know if the zoo is weak)...
I think than deng have to build frames with diferent geo and resistance (deng says than for the 2009 are going to build more frames, we are waiting :lol:), for suit all the riders, because they sell what they want but you have to pay it and...THEY CAN DO FRAMES!!!we don´t...
exaclty, see the CZAR, weights a lot for his resistance,but if that weigh was good distribuited, it can be a strong frame...
Edited by leotrialp
That is clearly what I had already said so no I am not wrong :)
I would argue that it is drastically wrong, which does make it hard to be ridden for it's purpose. I found it extremely difficult to stay on the rear wheel in a confined space with 375 CS, and it's much more difficult to turn in place as well.
Its down to preference, I would prefer the chainstays on a bike to be slightly shorter. It feels better for me when I'm getting up stuff. Balancing on the back wheel dosn't bother me, I'm fine with that.
Not sure why, but I've always found it easier to turn with shorter chainstays. Yet again, down to preference.
You've just got to find a frame that suits your style and preference at the end of the day, the older echos suit me down to the ground.
If the chainstay was something around 360, then I would start getting woried about it exiting out of the trials geometry catogery.
