Stupid Aluminium Bolts Again!
Duncy H
Right, I came to take the stem of my mod and one of the bolts has rounded and wont come out. I believe it is aluminium and is on a try-all nuc stem which means that the bolt is kind of sat inside a hole and is difficult to get to if I were to try cutting the bolt and then using a screwdriver. Anybody got anytips?
Hey Duncy H,
cut the bolts with a blade in between the stem gap.
Remove stem.
Post Mrs her forks- :lol:
Seriously though:-
I have the same stem, I don't think the bolts are aluminium on mine, but if you cut carefully between the gap (very carefully mind cos I think she's gonna buy your stem too), then obviously the bolt head will fall out.
Then the other part of the bolt should just screw out the remainder of the bolt, you may have to soak it in wd40 or better yet Plus gas.
If your feeling lucky cut the bolt as before remove the bolt head, and get a smallish drill. Drill the bolt from the head side and it should just screw out the other side.
Good luck
Matt
