Onza Zoot Pro... Build Finished Updated
Gaz96
I am currently building up this Onza Zoot Pro, I have most parts ready, just needing back wheel, rear sprocket, pedals and chain. I just put some parts on my bike tonight to see what it would look like roughly but I might paint it, and this was where I would like help/opinions... options I was thinking
1. Keep it as it is
2. Frame kept the same but forks sprayed black
3. Frame stripped to the raw metal and forks sprayed black
4. Frame and forks sprayed black
Just to let you no all components will be black except the bashring is green, so please comment any opions would be good
Just got it built up the other day,decided I liked the colour scheme in the end but might still spray forks black though at some point though...
Riding it brakeless just now will be putting brakes on at some point, but brakeless is really fun! Will also post a spec up tomorrow.
What do you guys think?
Riding the bike with brakes now! Brakeless was fun, really want another brakeless bike but I need a bike with brakes as a priority over brakeless so here it is with brakes. I miss the clean look from brakeless and the carbon frame protector ruins the clean look aswell but I still love it! Black seat im thinking, what about you guys?
Let me know what you's think now!
Spec-
Frame: Onza Zoot Pro
Forks: Onza Zoot Pro
Front Hub: Trialtech Sport Disk
Front Rim: Trialtech Drilled
Rear Hub: Trialtech Sport
Rear Rim: Inspired Pro CNC Sidewall
Tyres: Maxxis Holy Roller's 2.4
Tubes: Kenda Downhill
Rim Tape: Trialtech
Handlebars: Echo TR Riser
Stem: Giant 70*10
Grips: Trialtech Foam
Headset: FSA Xtreme Cartridge
Top Cap: Trialtech
Seat: Onza Plastic Purple Pivotal
Bottom Bracket: Onza ISIS
Cranks: Onza Zoot
Bashguard: Onza
Pedals: Onza
Freewheel: Tensile 60 Click 18 Tooth
Sprocket: Trialtech 13 Tooth
Chain: KMC Z510 HX
Frame Protector: Pro-Carbon Carbonfibre
Rear Brake: Magura HS33
4 Finger Lever blade
Try All Metal TPA Wheel
Monty Hose Splitter
Pads: Rockman Blues
Booster: Trialtech Sport 2 Bolt
Clamps: Blue Adamant
Thanks Garry
Edited by Gaz96
Personally I love the colour scheme, do see what you mean about the forks being black. I think it would depend on what your plans were for the rest of the bike, but looks sweet how it is. B)
Well I was planning to keep bike black as possible, originlly I would of went for a black frame and forks but this frake kit came up at to good a price to refuse! (thanks Ross McD) so was thinking along the lines of keeping the frame as it is and spraying the forks and making everything else black, I think thats what i'll probably go for
Black and white always looks great - pop up some more pictures when it progresses more. ;)
  • 1 month later...
  • 2 weeks later...
