Froks Won't Come Out Of The Frame!
t-bird tom
Ahhh okay cheers lads :)
Yeah i am using a rubber one.. is that not suitable then?
Yes it is, just a steel mallet will impart more shock loading and break the stiction easier. Rubber mallet is better because you wont be burring over the top of the steerer tube :)
I almost cried a few weeks ago as i thought my frame was dead as it had a duff old headset in it that'd been in for about 8 years. It was screwed and wouldn't come out.
I went to CRC picked out a new frame, slightly annoyed at the loss of cash, but thought i need a new frame....then i realised i was 'special' but not in a good way, in a "are u f**king special mate" kina od a way. I had been using a rubber mallet to no avail. Switched to a good ol' fashioned hammer and it was out in two seconds flat.
This method i think will work equally well for forks. If they're a bit stuck the rubber mallett might just be absorbing some of the impact. Switch to a hammer and i reckon they'll be out very quickly.
Surely you could just unpick some of the tighter stitching?
And I suppose you also suggest I have these expensive froks butchered back together by some high street dry cleaner too?
