Csc New Brake
trialsiain
The little springs are the pad retention system, which isnt ideal.
The slaves pistons aren't retained within the slave, as per magura/echo slaves.
They can slide straight out. Its just vacuum pressure holding them in.
They've missed a trick there for sure. I could see them being far more appealing with an integrated piston, with a sprung return and the conventional pad retention system.
  • Like 1
They just look a bit shite in general.
Its dead easy to set up a brake using clamps and washers, even easier with washerless clamps.
I could imagine that the integrated slave/clamp could be an issue on some frames, especially in terms of vertical adjustment.
Go on...
It's pretty much been covered really. Having seen the amount of riders who break/damage bolts too, using tiny little bolts for the cylinder adjustment seems risky. They shouldn't need to be torqued up much but I don't think that'll really make much difference to how much people really do tighten them.
What also seems weird is that to tighten/loosen the bleed bolts, instead of using a cap head system like Magura bolts you have to use a thin allen key perpendicularly through the bolt head. I don't really get why you'd opt to do that...
did they make these with the intention of not using any of maguras patents?
It seems that way.
