Hope Pro 2 2007 Problems.
Danny Kearns
Hello all
I went out for a ride the other day and My back wheel all of a sudden started rocking side to side which is also causing my tyre to rub on my frame somewhere, Everything is Tight I double checked that and yet it still Moved. I have taken the wheel off to see if the lock ring was loose, But it wasn't.
I then noticed that when I pull the side where the lock ring is, it moves in and out like half an inch.
Has anyone had this same problem, or similar. If so how can i sort it out as it slightly worried me.
All help will be appreciated.
Danny.
Right. Can someone link me to where i can buy a new axle for it please ?
Thanks for all the help.
Danny.
EDIT:
Found this one:
http://www.chainreactioncycles.com/Models.aspx?ModelID=18757
But which one out of the list do i need for my hub ?
Edited by Danny Kearns
Should be bearings................
iv not had any problems with my hubs, but from speaking to others the bearings have collapsed.
Only heard of 1 axle snapping, and that was Brett Penfold.
Wayne.
Damon snapped one although if anyone was going to, it would be him.
Danny.
EDIT:
Found this one:
out of the ones on that list danny, i would say its the one that says trials / singlesped....
