Do You Pull Both Brakes When Doing An Endo/stoppie?
LukasMcNeal
Do you pull both brakes when doing an endo/stoppie?
101 members have voted
  1. 1. Do you pull both brakes when doing an endo/stoppie?
    • Yes
      33
    • No
      48
    • Sometimes
      34
I would like to know if you pull your front and back brake when doing an endo or stoppie?
Why do I want to know may you ask? Well its because I found it weird because I always do, generally because after endo(ing) i'm most likely to go onto the back wheel.
Edited by LukasMcNeal
doesnt your left braking finger move very quickly?
hehe :P
A spinning wheel weighs more then a stationary wheel.
:huh:
Only way I can see stationary/moving making a difference, is if it's spinning fast on the way up, then lock the brake off when you're running out of momentum. Centrifugal force'll send it pivoting 'round the front a little bit extra.
Same as what some people do for taps, but in reverse :P
