Pure White
EchoSam
Just got a few new parts for my Pure.
Spec:
Frame - Pure '09
Forks - Because
Headset - FSA
Stem - Echo HiFi
Bars - Trialtech Sport w/ Halfords BMX Grips
Front Brake - Hope Mono Trial Carbon/T.I 200mm
Rear Brake - Magura, Black TPA w/ TNN CNC Pads, Echo TR Clamps, Hope Braided Cross-Over and Toxin Booster
Front Wheel - RockMan BUB Hub, Trialtech Square Hole Rim, White Rim Tape, Black Spokes w/ Blue and Black Nipples
Rear Wheel - Hope Pro 2T, Surley 15T Sprocket, Echo SL Rim, White Rim Tape, Black Spokes w/ Blue and Black Nipples
Front Tyre - Try-All Sticky
Rear Tyre - Maxxis Minion 2.35 Dual Ply
Chain - KHE Collapse
Chain Tensioner - 4-Jeri
Cranks - Middleburn Square Taper w/ Cloud 9 Bash Kit
BB - Neon Carbon Taper
Pedals - Bikehut X-Platform
Im toying with the idea of getting a white stem and maybe white headset.
Opinions would be helpful =D
Cheers
Sam
Really nice spec the wheels look epic, however that frame dose nothing for me, its looks like a failed attempt of a frame.
the chainsteys looks weird ( know it was like this on the 07 model however the white makes them stand out much more)
and the seat tube looks really thick. dosent do much for me.
the white/black/silver works well (Y)
EDIT: on a more bike related note, matches the dog very well (Y) topmarks
Looks lurvly
I wouldn't get a white stem, it would sort of be too white
How'd you find those forks flex wise?
Compared to my viz lights the forks feel pretty stiff. The viz were quite flexy though.
looks good! interesting chain tensioner set up. is it working well like that? chain is very short for vertical dropouts
The drive does feel a bit rough because of the tensionner, but the only reason the chain is so short is because I did have perfect tension but the chain stretched =( I am thinking of going 18:16 instead of 18:15 because it did feel a bit nicer.
  • 2 weeks later...
