Which Is Better And Why ?
Jeromboii
Completely wrong!!!!!!! 20/26/24 are all designed for different styles of riding. You can be 6 foot and still ride a mod and 5 foot 5 and still be ok on a stock.
Try and get out on each one have a go and see what you feel you suit, I have ridden all types over many years and each type has helped me progress on the other...
It all depends on you style and what you prefer as said earlier there are 6:5ft + poeple who find mods comfy and pretty short guys who ride 26 .
20" and 26" are pretty decent all round bikes for street , natural and comp style riding whereass 24" in more for street style moves incorporating bmx and trials tricks .
You've obviously never seen the 24" frames designed for pure trials.
It'll be interesting to see where 24" bikes fit into things now they're a bit more accepted by everyone. Savage was doing some mental shit on his Kabra when I saw him riding that in Porthcawl, and Benito had a pretty decent 24" video out a while back too. Seems like more 'big' companies are getting involved with it.
Pretty good site that helped me choose when I was starting out.
Choosing between stock and mod
Both modified and stock trials bikes have pros and cons:
Modified (20" wheels)
  • Pros:
    • Superb standover clearance
    • Easily manueverable in most every circumstance, especially anything rear wheel
    • Less expensive
      • Less parts to break
      • Nearly impossible to bend the rim of a well-built 19" rear mod wheel running enough tire pressure
      • Learn to sidehop up to both sides without worrying about a rear derailleur
Cons:
  • Some people may think it's a BMX bike
  • A pain to ride more than a mile or two on
  • May be harder to find parts for it
  • Harder to roll down things
  • Easier to go over the handlebars (but less scary when you do)
  • Doing wedge or wheelbase moves is less comfortable
pixel.gif Stock (26" wheels)
  • Pros:
    • More stable
    • Bigger wheels = roll everything easier
    • Easier to do wedge or wheelbase moves
    • Easier to pedal-kick on odd surfaces because of the larger diameter wheel
    • You can ride to your riding spot easily (if you have a seat and working gears)
    • Looks more like a mountain bike
    • People won't ask you to "grind" stuff or think you do BMX vert or street
Cons:
  • Bigger bike = less standover clearance = pain if you fall on the bike
  • Easy to hit knees on top-tube of most bikes
  • Less room to work with for bending down before sidehopping, bunnyhopping, etc. or when absorbing landings
  • More expensive because of greater frequency of breakage and more parts to break
    • Rear derailleurs - easy to smash into things (though most bikes have replaceable derailleur hangers that will bend before the derailleur is broken)
    • Wheels - 26" size = easier to get out of true or taco (20" wheels are extremely hard to ruin when built and used properly)
    • Chain can slip down or up a gear while you ride if your chain is too loose, or you smack your derailleur in section and break it
    [*]Heavier
The information is a little dated, but it's still solid advice (Y)
  • 3 weeks later...
