James Hyland's Sky 2
Mark W
James popped in yesterday to tweak a few bits and pieces on his bike before heading off to this weekend's UCI World Cup over in Switzerland. While he was here we got a couple of photos:
Frame and Fork
- Frame: Koxx Sky 2
- Fork: RockMan Spade 4-Bolt, Silver
Wheels
- Front hub: Echo TR Non Disc
- Rear hub: Try-All 'H'116 Non Disc
- Chain tensioner: Try-All 'H' Snail Cams
- Front rim: Trialtech Sport Front Rim
- Rear rim: Try-All hOles 2012 4.7
- Spokes: Triple butted front, double butted rear
- Rim tape: Try-All, Black
- Inner tube (front): Kenda
- Inner tube (rear): Kenda
- Front tyre: Try-All Shift 26 x 2.0"
- Rear tyre: Try-All Stiky Lite 26 x 2.5"
Brakes
- Front brake: Magura HS33 2011 (Long lever blade)
- Rear brake: Magura HS33 2011 (Long lever blade)
- Brake clamps: Try-All
- Brake Pads: Koxx Yellow Croco (Front) and Coust pads (Rear)
Drivetrain
- Cranks: Try-All CNC ISIS, 175mm
- Freewheel: Echo SL 108, 18t
- Chain: KMC Z610HX
- Rear Sprocket: Try-All Screw-On 15t
- Pedals: RockMan Single Cage, Silver
- Bottom bracket: Try-All ISIS
- Bottom bracket bolts: Steel M15
- Bashring: Try-All Symetrik, Black
Steering
- Headset: Try-All Sky 2
- Stem: Try-All 3D Forged, 150mm x 30°
- Grips: Try-All Foam
- Handlebars: Try-All Carbon
...this bike's also up for sale, so give James a shout if you're interested!
  • Like 1
why not just have flat bars with a change of dimensions on the stem?
Mainly 'cos you'd need some mental 180 x 15 stem or something like that I guess. Plus this way when time passes people can just roll their bars back, and won't have to buy a new stem 'n' stuff :P
hope it rides alright
cause it looks....wrong
Jack Carthy and James came round last week to get some bits and ride our indoor setup. Although you could probably put them both on an Apollo and they'd be able to do some serious stuff, they were definitely riding their Sky 2s well!
  • Like 1
yeah
no doubt about that
it's just like lycra stuff, efficient but so fugly to the eyes
I dunno, I think it looks great. It kind of changes it from looking elegant to looking like serious business. And with regards to the change in ride, I love a tilted forward bar. It makes rear wheel class, helps on pedal ups and on gaps to front aswell as normal gaps. And it feels right, Because you're arms aren't being held inwards by the bar angle, they offer much more control and leverage.
