Wheel Not Straight In Forks.
dann2707
This is a right pain!
I go to put my front mod wheel in my viz forks, completely slammed in the drop outs however it is right to one side.
An even bigger problem as I have front disk now so the rotor isn't parallel to the pads meaning it's rubbing all the time..
Any ideas how to sort this? Never encountered anything like this before .
Thanks a lot.
Edited by dann2707
Weird, is the dropout worn down on one side?
Nope! That's the strange thing. It looks perfect. Tried it in my echo Urbans and its straight as anything so it's not the wheel slash hub.
Almost like a manufacturing defect? :( not happy as the disk is always rubbing.
If I filed the dropouts though, how would I ensure its absolutely perfect? Just seems a bit of a risky manovure I don't think I'm competent in tackling haha.
Nope not tested any other wheels but can do asap.
Test another wheel, if it's not straight either... Then send forks back if you can, if not possible at all. Just file it down and keep putting the wheel back in until it's straight. That's how you can ensure it's perfect, as filing it won't wear it down particularly fast.
You sure it's one issue? Is the wheel actually leaning over at an angle in the forks, or is it just dished over to the side?
If the wheel is leaning over in the forks, you could file the offending dropout to get the wheel straight, but bear in mine that it could spazz the disc alignment up further, be extra careful lol.
If the wheel is just dished over to the side, (far more likely), then the disc issue may not be linked. In this case, I'd recommend getting the disc mounts faced and shimming the brake up properly (buy proper shims, not just washers). I'd ignore the wheel being dished a bit, doesn't really matter with a disc wheel (within reason).
Thanks for all the replies :)
I don't think it's the wheel that's the problem as said, I stuck it in my urbans and it's as straight as anything, absolutely perfectly aligned like it should be.
I'd go back to my urbans but the steerer is really short so I couldn't use any stem stackers which wouldn't normally be a problem but with this stem and bar combo it's gonna feel mega too low. No up to fronts for me.. ha
Got a few pics.
Measuring from the rim wall to the inside edge of the forks. One side
Other side
Edited by dann2707
Try tightening the spokes on the opposite side to the lean? Or loosening the side that leans? Then re tension the lot? Just an idea?
If the disk rubs the pads, i.e the disk isnt true to the caliper, it isnt an issue with the dish of the wheel.
Unless he's unfortunite enough to have a wheel thats not dished correctly, and brake mount that needs to be re-surfaced
Dam, snaked by dan :P
  • Like 1
I thought that as soon as I posted them pics but then again why would the wheel be so far out too? Doesn't make sense? God damn itttttttttt why is stuff never simple I just want to ride my bike :( haha
Probably worth just admitting the forks are f**ked then :( grr
Hardly rode it Carl. Mod felt shocking so I just jumped back on stock. Never noticed it.
Drill some holes and twat it with a hammer.
Best advice ever ;)
On a serious note dan, you might get away with using an adjustable spanner, and gently bend the disk tab back in. It properly wont be perfect, but you cant make it any worse :P
To try and solve the disc issue, if you've got a good local bike shop you could get them to face the disc mount for you, then use some thin Hope spacers to get the caliper perfectly aligned with the rotor? Takes some of the guesswork out of it.
