Home Made Crank Extractor
David
Hey, don't know if this should be in here or chit-chat. Anyway you may remember me asking lots of questions in chit-chat about making a crank extractor for my GCSE project. Well its finally done! Its not perfect at all, but seeing as its my first time using a lathe/milling machine etc I think ive done ok.
While manufacturing the tool I came accros the problem of not having a die stock big enough to hold the M22 die so I had to make a one myself:
Edited by David
Cheers for the comments guys. I'm considering making a few more things when I get time, maybe after my exams. :)
It looks really good mate! I would be interested in buying one if you did make some more. (Y) :D
EDIT: Whoops!! I didn't read your reply properly! Sorry! :">
Edited by Sid@yate_trials
Just having a second look at it... although it's still a brilliant job and you're obviously very skilled with the old lathe and milling machine...
Theres not a lot of innovation there, I mean you've just copied an old design really. Don't get me wrong, I still think it's a top job but theres nothing special about the design - sorry!
Although I suppose why fix what isn't broken... So I have just contradicted myself... But yeah.
(Y) INNOVATE :)
:) INNOVATE :D
I agree with you there but there isnt much you can really change. I have though used a deeper pictched thread on the tool which makes it stronger then most you can buy. The 'standard' thread is usually 1mm pitch but I used 1.75 (Y)
Why not try making one for a crank with a stripped extractor thread? I know I'd love one (Y) With my cranks, if I strip the extractor thread it generally requires me riding it without a bolt in just to make it drop off, but it'd be a lot easier if there was a tool out there that used the same principal as a normal crank extractor, but the main body of the extractor (the bit that usually gets screwed into the crank extractor threads) had some kind of clamping system to clamp it to the crank arm?
you want something along the lines of this http://www.neotechworld.com/extractors/pul...-extractors.htm
ive seen better designed ones that are a lot simpler. Basically it will grab your crank and pull it away from the axle
Very nice. Looks like it could take a beating, tools these days arnt made very stong at all. Its not like they need to be super light like bike parks.
:lol:
Thanks for all the comments. I'm currently designing a few bits and bobs (tools and bike parts). Once I have time I will knock up a few models/prototypes on the cnc machine. Nothing special as im still learning everything! Hehe. Dave
I have though used a deeper pictched thread on the tool which makes it stronger then most you can buy. The 'standard' thread is usually 1mm pitch but I used 1.75 :D
:ermm:
Not saying anything else cos i remember posting a load of poo when trying to help last time.
It looks like a nice job - i especially like the fact you knurled that bit of it :P
Andy
