Hickups(sp)
thesubway
drink a glass of water from the wrong side.
so instead of drinking from the side nearest you drink from the one furtherst away, you'll sort of have to bend over/upside down.
it sounds tupid but it's worked for me a few times.
i can't actually remember the last time i had them though, so maybe it's even a cure. haha.
Yeah hiccups are just spasms of your diaphragm so like people said you just need to really focus on controlling your breathing.
Should work.
I also just found this... interested to know if it actually works..
(1) Pour a TALL glass of water.
(2) Hold your breath... ***
(3) IMPORTANT...PINCH YOUR NOSE CLOSED.
(4) Slowly, take 10 - 20 swallows of the water...while holding your breath with your nose pinched closed.
(5) When you can't stand it any more....you'll know by that overwhelming drowning sensation -- after a gasp, take a deep breath and relax.
Edited by nichols_sam
Should work.
you don't even need to use the water, you can do it by just holding your nose and swallowing air without breathing in, do it about 10-20 times as stated above and then you should be cured. Just don't burp straight after and dont start back on the beer again or you'll get them back.
