Cutting Steerer
fyfey
The most accurate way is to place them through your frame and headset, put your stem on and push down making sure nothing is loose.
Draw a line around the top of the stem on the forks steerer then take your forks out. Now get the stem and put it over the fork steerer and draw another line around the top of the stem approx 3/5mm below the line you drew before.
This way you get a perfectly straight line which will give you a parallel cut to your stem, just hacksaw across the line.
Also, make sure you hit down the star nut if your forks already have it in.
Phil.
Buy a couple of steerer tube spacers, this makes sure that when you cut your forks down they are not too short for a new frame or for flogging later.
You may also need to move you star fangled nut down (the nut in the steerer tube). Take the bolt from your headset and screw it into the star fangled nut, put a block of wood over the bolt and hit it with a hammer. Do this after you have marked up the tube for cutting so that you can move the nut below the cut line before cutting, so you don’t cut your nut (which is bad).
If you want to get a perfectly straight cut, get some tape (electrical, masking - you choose) and wrap it around the steerer. Wrap around neatly enough and it'll be perfectly straight. Then just get a hacksaw.
Those pipe cutter things are a lot easier and quicker but most people don't have one of them lying around, so a hacksaw is fine.
A Hering?
Right after cutting down the biggest tree in the forest with it?
Sorry, anyway, yeah, I've found the tape method to be best before. Make sure you use a decent hacksawblade aswell. Not a blunt one or a jr hacksaw. It makes it alot easyer.
Jubilee clip over the steerer, mark where you want the line with techniques used above.
Stick jubilee clip on steerer at line and saw away.
You will geta nice straight line with that (Y)
Nice idea!! I think I'll use this method.
Gives something physical to saw against, should keep it nice 'n' straight!
Cheers guys,
Fyfey :turned:
