Echo Pure - New Paintjob
Mowgli
Hey,
Got bored and bike was horrible to ride so a good powder coating and some new bits are making me smile. Going out on maiden voyage in an hr or so.
What it used to look like....
And Now....
Parts changed:
New Wellgo MG1's (from china)
New Lock-on grips (ebay)
74 Kingz Tensioner (T.McMillan)
Adamant Headset (kcChan)
New VP Sq Taper BB (tarty)
Do you think it needs echo stickers??????
Look forward to your comments.
Regards
Hey,
And Now....
Parts changed:
Regards
that looks realy smart! same clour im sprayin my 72 beetle:P
personlay id leave stickers off would spoil it but if you like them on do it m8 ur bike :P
thank god im not the only one thinking that.
love the colour but where does your cable come out of??
goes in the frame where u can see by the headtube and back out on top of the seat tube just before the booster.
Cheers for the comments guys.
Quick question - how do you route your brake lines? Remove the main hose and bleed after reconnecting? Small hole to small hole can't be easy so I'm assuming you've done something sensible!
i dissconnected the cable from the lever and cut off the olive too. poked that in the bottom end of the frame, when you can see the hose by the top hole i used something pointy (a sharp pencil etc) to stick in the end of the hose to guid it out the frame which pushing the cable through at the bottom end.
Its suprisingly easy.
Regards
I bet it looks different in the flesh!
it does, a bit brighter, the pictures have dulled it down a bit. you may see it at the comp if my hub returns in time.
I got it done at a company in Gosport called plasticoat. It cost £30 for frame and forks (would have been less if the forks were the same colour). To do it you just turn up and walk in, it will cost a fortune if you ring them and ask about it.
i like it mate....yet another green bike out there....kinda reminds me of mine a tad lol.
like the bloke said before bout the white rims...look at mine and that tells you kind of how it will look with white rims.
x
what is it with everyones hopes goin wrong atm, is there a bug going around or something!?!
once the foot is healed i'll get my self down to portsmouth for a ride (Y)
mine is working perfectly now, love it.
i hope to see u at dj ride if your cast is off!
