Heatsink Pads
SkiLLz
Coust - YES!
Been told reds die on grinds ? Never tried though ?
Rich Pearson swears by heatsink reds!
I've run Heatsinks (cousts and reds) for ages now, and they've always been excellent
Not had any issues with wear (my current set of reds have been run on a grind for around 4/5 months now, and still have well over 5mm of material left. What more could you want for £8?!
Then order them from Trials-UK?
Steve does have a full time job and a family to look after, people seem to forget that. He always tries his hardest to get shit sent out asap but every now and then there are hold ups.
Ok understandable, but the pads are still not the best, and far to unrelieable, I found...
And I didnt even know Trials-UK sold them...
Try Yellows. I gave Yellow CNC pads to a friend for his birthday and within a matter of an hour his brake was amazing - super loud, loads of hold and bite and all that on a grind without tar or any other sticky substances.
He said the brake was too aggressive to his liking but for some that can be a good thing.
edit: Cousts on a smooth rim are good, with a bit of tar they're just as good as on a grind as long as the rim doesn't get wet or dirty.
Edited by Inur
Thanks man!
I just got some coust pads, had rock blues before. My setup was working quite well with the blues, put the cousts on the same rim setup, and they were much louder, but didn't hold as well. I'm going to regrind before next ride, see if that helps a bit.
Coust - YES!
The set of Reds I've got on the rear have been on there for over 8 months now, and I reckon they'll probably see me through to the end of the year. And yep, they are the shit when it comes to raw stopping power and bite. Even in wet weather they really seem to get to work after a few minutes warming them up.
Couldn't ask for anything better.
Rich
Noooooooooooooooooooo! You have to let pads bed in before they start working properly, so by re-grinding your rim you've now got to let the grind sort itself out, then the pads wear into the grind, etc...
Have got cnc cousts front and rear on a grind and they are amazing.......mega bite (have been over the handle bars twice which was a embarrasssing) hold is mega too.
Steve got them out to me in about 3 days which i thought was awsome of him.
A touch on the pricey side though
tom
