47mm Or 38mm Rear Rim For 24"
zoster
Hi!
I am buiding a new custom frame at marino, and i must decide what distance between the v-mounts i want, therefore i must decide how wide i want my rim on the back.
What would be the advanteges of a narrower rim? (a 38mm one)
If it's about tire roll, i don't think tire roll is really an issue if you keep the tube on a wide rim at a fairly high pressure (how i like it).
thanks
looks like you answered it yourself really, go for 38mm, its gonna save a few grams too :)
i can't see how i answered my own question..
i was saying that a wider rim doesn't really mean more tire drag
anyway, if you all say 38 is ok, then i guess is ok, but i stii don't know why it is better then a 47 one...
narrower rim and a narrower tire, easier for spins as a smaller contact patch with the ground. i use dx32's on my 26" with a v and its more than wide enough, running a 2.4" tyre at 18psi and dont tend to get much tyre roll if any, so with higer pressures you'll have none. if you dont need the extra grip that bigger volume tyres on a wide rim at low pressures gives you then go for the 38mm rim.
Go for a 38mm, anything more is just excessively wide imo.
We all used to ride on d521, which were sub 30mm(27-28ish) if i remember correctly, back then we never moaned they where too narrow.
I'm running a dx32 right now, dont really have an issue with its width.
Think going wider than about 40mm is stupid. Stick with 38mm, and if for some reason you feel the need to get a 43mm rim, you can always shave a couple of mm off pads to get the extra width if they wont fit(or better still buy second hand pads) you go for 43mm, and decide youd like a narrower rim to save weight and make streety moves a bit easier, your a bit knackered
if you looked 4 posts up :S
i did check that out before i posted, and indeed it would be great for the front, but i didn't seem to find it for sale (i'm from romania so there are restrictions.., but i didn't look much for it yet)
>_<
Wrong thread, or can't read? :giggle:
Nah for once I think Matts spot on the point, and something none of us had though about, by putting the V mounts further apart on a 24, theyll be way more succeptible to catching your heel/the crank arm, if your catching the crank arm, youll have to have a wider bb to clear the V brake arms.
I would go with the DX32 on the rear, as you do run higher pressure and it's generally an all round rim. If the frame is suited to 38mm rim then your have no problem switching to a much skinnier Mavic if your using Vee rear.
Ryno Lite welded would be a happy medium for the front i'd say. Or even the rear. But as long as your sure you don't need a massive rear rim for the rear then rims aren't a problem to change at a later date, no?
i'd LOVE some dx32's, but i can't seem to find them in europe, only in the states..
about the front rim. i see many guys use quite wide ones (same width as on the back), but something around 30mm should be enough i reckon, nu?
Well i running a 47mm VIZ rim on the rear of my Inspired, and it works great a bit thicker, bloddy well strong has taken a real beaten :P and seems to feel alot nicer than my old Onza Ronnie rim which was 37mm.
Alex rim's never :lol:
Edited by thewoomaster
WOO, what's with the worm on the front of your bike? isn't that like 1500g or something?
don't you make me second guess now! : )
i made up my mind and i am getting a trialtech rim. don't know if drilled or not though
