Math Help
Robwalker
Excuse the crap picture and writing etc, I've got a f**ked right hand and a stinking cold.
For the same reasons it's probably worth checking properly as I'm not exactly thinking clearly today either :P
You've got the product of two functions which you're trying to integrate so you'll be wanting to bust out some integration by parts;
I've not been back over it and checked it all makes sense, but even if it's not it should give you a few ideas with a bit of luck.
Oh god i absolutely hate c3 maths, must have failed it really bad this january so don't believe all i say :P
But basically i do believe that integration by parts should be used.
so basically
let u=x and therefore du/dx=1
and let dv/dx=e^2x and therefore v=1/2e^2x according to your model
The integration by parts formula is as follows...
So using that formula...
The integration = (x)(1/2e^2x)-1/4e^2x
= 1/2xe^2x -1/4e^2x +c (However the +c is not necessary atm)
Therefore using the original boundries of 1/2 and 0...
=[1/2(1/2)e^2(1/2) -1/4e^2(1/2)] - [1/2(0)e^2(0) -1/4e^2(0)]
Now that should hopefully = 1/4 but i have most likely done it wrong :P
Edit: made at least one mistake and corrected it
Edit 2: Ahhh beaten to it!! :P
Edited by Duncy H
The integral of xe^2x is
((xe^2x)/2) - ((e^2x)/4) (look up integration by parts if unsure how)
which simplifies to
(e^2x)(x/2 - 1/4).
Then with F(0.5) - F(0) you end up with
(e^2(0.5))(0.5/2 - 1/4) - (e^2(0))(0/2 - 1/4)) =
(e^1)(0) - (1)(-1/4) =
(0) - (-1/4) =
1/4
Edit: Knew that would happen. Hope it's all clear now though :P
Edited by ManxTrialSpaz
  • 3 weeks later...
  • 2 weeks later...
Can someone check this over for me? I think i've got it... but just want to make sure i'm not missing something out here:
If
y=4/5(1-e^(-4t))
then multiplying out of brackets
y=4/5-4/5e^(-4t)
Now to differentiate:
as y=e^(ax) dy/dx=ae^(ax)
dy/dt=(-4/5)(-4e^(-4t))
dy/dt=3.2e^(-4t)
Do you concur?
Most entertaining thread on TF.
I took AS level maths. Dropped it after 3 months, then dropped out of sixth form. I can do geometry stuff easily (cos it's like engineering only simpler), but could never do all the magic shit you lot are drawing up there.
