Bounciest(?) 26 rear tyre
Kevinfor
Hey guys!
So ever since I got my zoo I've had a maxxis hi roller (2.35) on the rear and i like it its a nice tyre.
But last night I moved back to the kenda kinetic that the bike came with for no real reason just thought I'd wear that one down a bit and it feels like i can go bigger with the kenda than with the maxxis, as in longer gaps and higher sidehops, which I like.
So basicaly what I wanted to ask is there any tyre thats got even better bounce? Not too bothered about price or weight but the frame seems to be quite narrow at the bb yoke thingy so I only have about 4 or 5 mm per side with the kenda tyre so no uber massive tyres please.
Oh and are the tubes marked as "downhill" or "freeride" bigger as in volume than the crap I can get at my local sports store?
Thanks a lot!
Kevin
Edited by Kevinfor
downhill tubes are thicker, and I've found tend to be bouncier.. don't really know what to suggest but I use try all stickys, when I moved to them i've used nothing else..
I'm sure someone will back me up on that, they're really grippy.. there could be bouncier tyres out there, but i've never tried them...
I bet that makes no sense.. i'm rambling a bit...
EDIT: just realised you asked one question I gave you a completely different answer :giggle:
sorry about that...
Edited by Danny00135
Get a Continental Rubber Queen man :) they have thin sidewalls which is where the bounce come from, also makes them light, but get a downhill tube in if you run one to reduce risk of punctures.
Adam.
oh by the way....for the rubber queen you will want the foldable one without the strengthened sidewall bead !
Adam.
Thanks a lot for all your replies guys!
Rubber queen seems to be the one to go for but just to clarify, does it matter if its this: http://www.tartybikes.co.uk/26_inch_tyres/continental_rubber_queen/c33p10725.html or http://www.tartybikes.co.uk/26_inch_tyres/continental_rubber_queen_ust/c33p11550.html ?
Thanks a lot!
Kevin
Try-All sticky (lite) has quite bad spingyness and about the highest rolling ressistance, especially on pavement and when pushing it hard to the ground at pedalups. My big favorite now is Schwalbe Wicked Will Gooey Gluey 2.35. It has very good springyness while offering very low rolling ressistance and perfect grip on all kinds of surfaces.
post-12833-0-75237300-1357902921_thumb.j
Edited by marko
