Hope pro 2 shortening (dave33 help please) *finished pictures page 4*
Blake
Looks pretty tidy. I look forward to seeing the full wheelbuild and some footage of it in action.
Cue the masses of PM's from people asking you to do one for them now!
He can just buy some free hub bodies and modify them to sell
  • Like 1
Would it be worth enquiring directly with Hope? As possibly the most helpful, accomodating bike manufacturer I know of (no offence to any others) they might be interested to see what you've done and could do you a good deal on a few bits maybe.
  • Like 1
Might be a bit expensive at that price, be cheapest if some one had a 2nd hand hub they wanted to mod
Like I said I can do this if any one needs.
It's going to have to be dished fairly dramatically.
Are you running rear disc ?
The non drive side is as standard.
I have left it like that so you can run a disc if you so wanted to :)
otherwise, whats the point ay?
Well if you wasnt bothered about running disk, it'd mean you didnt have to modify the drive side as much, so you'd have a bit more adjustment for the sprocket to get better chain line, and the hub flanges would be more central so you'd get a stronger wheel build and you wouldnt have to dish it as much.
  • Like 2
The dishing of it won't effect the strength of the build much at all. Being such a small, wide wheel as it is.
But yes, i could have cut down the end cap on the non-drive side a bit, and allow about 5-10mm of extra room. But that would have arisen other problems with the freehub body not being stable with only one set of bearings holding such a wide distance from the shell.
  • Like 2
