Chain help new kmc 610
Neon-trials
You can take apart one of the half-links from your BMX chain, take the 1/8" roller out of the narrow end and replace it with a 3/32" roller from the Z610HX chain you've got now. That way, the pin for the half-link will be nice and long so it's unlikely to 'go wrong' at that end, and it should hopefully allow your chain to stretch out a little through use which would allow you to run it without a half-link.
Those chains don't stretch alot. Your better off with a k710. That's if it's any near to going on ?
You could file the slot in the drop out an extra 1/2mm if it's near.
I wouldn't use a half link if I could help it. And not an old one that's been used for a while.
Any half links iv tried all snapped
  • Like 1
I'd say the z510 and the z610 chains stretch a shit ton when you first fit them
I've put a smaller tyre on the back for a while to see if the chain stretches enough for me to put my big Betty back on the tyres pretty massive the maxxis I'm using now gives a little more room for the wheel I've been out today for an hour and the chain seems a little slacker already so fingers crossed I will be able to put Betty back on
All my z series chains have stretched in seconds....
How heavy are you ? Iv had loads of the 610 chains never stretched alot. I would have noticed as I normaly hold up my old one next to new one to get the length right. Iv notice in the past with the kool chains that its nearly a link out difference
11 stone. . .
  • 4 months later...
Hi just found this topic...I just put a Z610Hx chain on my ride, and after 2 rides (not seconds but close ;-)) and its stretch about 5mm (total length of chain). Is this the initial pre stretch ? and it will keep this length from now on ? how long time do you run your chains before replacement ?
