CNC Work
george_seamons
A while ago there was somebody on here who did CNC work, I cannot for the life of me remember who though!
Basically, I need something made like the picture below (just the spacer plate, not the bung, bolts or gasket). I don't need the seal around it, literally just the big hole in the middle, and the 4 holes. Not fussed what material it is made from, although alloy would be nice. I believe the thickness is about 15-20mm.
I can get the measurements, and make a drawing, although its pretty simple!
Purely as I spotted it just now whilst flicking through the 034 sale, I noticed that theirs are 25mm thick as a reference. Obviously difference TB to yours as I believe these are standard 1.8t so the product itself is no use to you though :P
http://store.034motorsport.com/throttle-body-spacer-for-water-methanol-injection-audi-volkswagen-1-8t-wmi.html
Edit: Slightly offset too. No idea why, shouldn't need to be so I'd imagine it's to do with clearance on the outside to get around other components or something.
034motorsport-18t-billet-throttle-body-s
Greg, a mate of mine wants some rearsets machined for his custom 1982 long crank triumph thunderbird special; I was hoping to get the pieces pushed through at work but we're through the roof :(
Could you pm us an email address that I could ping some drawings over to? Looking to get a mild steel sample set done first and probably in aluminium at a later date.
Just save as a sketchup file and I will do the rest. Make sure you are working in MM, I can only do 130x130x130, so some pieces may have to be designed in 2 parts if they get too large!
MK1 of my chain guide, can't find photos of the revised version!
Edited by CurtisRider
  • Like 2
Chamfer will just be 0.015 just something to break the sharp edges really.
But yeh i will machine 2 at once out the block then split it and flash the faces to take them both to 15mm thick. Then job should be a gd un.
Also in the process of machining up a drive shaft. Just got to put the splines on the end once i get a chance aswell.
  • Like 1
