Hope Pro2 116mm conversion
Scott Gibbs
flipps was made by josh leech, mine and @isitafox was made by alex dark, but neither of them can produce any more due to current circumstances. i went for them over euan because the wheel rim wasnt dished, and it was a much more solid build. from what id heard, Euan just machines the driveside down. when i asked him if he could do mine, he said it wasnt possible for him (110mm) and the Alex went and did it perfectly anyway. so its a bit of a difficult one.
Edited by Herbertlemon102
  • Like 2
On 16/11/2018 at 11:59 AM, monkeyseemonkeydo said:
Are the flanges on the 150 wider than a normal 135? If so I would expect you to struggle!
The extra spacing with the 150 hubshells is in between the non driveside flange and the disk mount, so the disk mounts will have to go but that’s not an issue really as I don’t use disk brakes.
  • Like 1
