Would I Be Right In Saying I Have The Stiffest Gear Ratio Ever!?
STEVE-0
Everyone finds my gear really stiff and just done a search and found loads of people have it well easy....
My theory was - surely it you could get used to a stiff gear you could go bigger, more power. I can sidehop bigger, tap higher etc.
Although for comps i do use 18:15 because the extra torque helps on those muddy slopes.
I always wondered why people could get such small run ups.
Just interesting really....so....anyone the same as me
retarded :$
Steve
nope i run 22/17 which is a slightly higher ratio unless im being a tard? :unsure:
I ran that for years and years, it was the original choice i think.
Im 20 /15 now but with ickler wheels.
Just use this
http://www.sheldonbrown.com/gears/
set the gear units to inches,,,thats how far u will travel given your wheel size and gearing,
But at the end of the day u need to try some different ones to see what feels best , then use the above calculator for informed tweaks.
Im going 32 inches per crank rev.
steve-o your going 31.1 ish( cant tell for sure , dont know your crank lenght and actual tire diameter).
Based on that i wouldnt say that your gear is that hard to pedal at all.
Edited by VillageDave
