How Long Does It Take?
stunt man t
hello people...
just woundering how long it takes,
when uve got your bike working as sweet as,
does it brake again >_< ?
i got a new bottom bracket for my mod last monday and everything
was working perfectly, until today :angry:
my bike brakes like every other week...
how long does it take you?
hello people...
mine broke today, i smashed the bashplate off so i bodged it back on :)
raise me a 10-er :)
Edited by Disasterboy
depends how much you spend, more you spend less chance of it braking !
Na, Think off it like this Echo brake £135 Magura £65 the magura is the one wich will always be working and alot cheaper than echo brake, Rear hubs King is expensive but i have found they break alot more that a good old pro 2 And pro 2 is alot more cheaper (Y)
Why are people actually trying to give answers? How long is a peice of string?
Can you foresee any manafacturing defults, you doing something wrong, you getting your hose caught on something, your freewheel just deciding to blow up? NO! Its trials its f**king expensive, so when do our bike break? all the f**king time. And if your ever expecting it to stop even when youv'e totally pimped out your T-pro forget about it, things do break and its impossible to give a product a lifetime estimate, as it depends on a million variables, ride style, accidents, slips, work shop errors, riding over a pot hole.... all things that ive done that have messed up my bike
How did you come to that conclusion? I've had about 6 kings now on all kinds of bikes and none of them have ever given me any trouble. I've heard of literally dozens of proII' exploding.
yesterday my brake suddenly stopped working, oil leaked from the pipe that is leading to the leaver :mellow:
I tried tightening it with a spanner, various sizer and this didn't work
i think there is still brake fluid in it because i can still press the leaver the pads just don't lock on AT ALL
Seeing as this is my first magura, i have no idea of what does what, or the names of the parts (learnt what TPA is >_<) or equipment
Any idea's guys?
The length from the middle to one end, doubled.
I agre with whoever said about "the more you spend, the less it breaks"
Freewheels for example:
Acs - A month if you're lucky
Eno - good year or two
Just keep things well serviced and look after your gear (Y)
My bodged-up Vee brake adapters play up a bit.
They bend outwards (need a booster...) and the bolt holding the Vee mount comes loose from time to time..
Apart from that, and my brakes needing new pads, my bike works fine. :ermm:
Well..chain snapped a lot a while ago, but I replaced it with a new-un.
Hows that even an anwer, its like saying is L is the length of string then its length = .5(2L)
So doesnt really come close to solving the equation.... and benjaminge, what a wasted post... its a shite answer
never really *touch wood*
ive never snapped or bent anything on my bike, sometimes i really wonder what other people are doing wrong!
check your bike regulary, and replace bits that need replacing regulary- chains every 3-4 months, bars and stems every year or 2.
but to be honest i generally buy new stuff more frequently than that. maybe its because i buy new bits things dont break?!
shite answer yes, but the length from the middle to one end is half the total length of the string. Double that answer and you get the full length of said string :rolleyes:
It is still a shite answer but an answer none the less :P
I'll bring a piece of string and a ruler to the next ride and demonstrate ;)
not really a wasted post
hardly wasted a lot of my energy
and my reply wasn't relevant to the rest of the topic,
just that one post.
so you, in fact, are wrong about that
heh you gotta think variables :) rider weight, riding style, ability to install stuff, general care taken. i usually replace parts before they get a chance to cause me pain ;) some people are just un/lucky
