£100 Heatsink Backings!
cai
From the news section on the Heatsinkbikes.com..
New XL CNC Backings!
During the machining of a batch of CNC Magura backings, the machinist accidentally leant against the button panel of the CNC machine. The result was a batch of elongated CNC backings which we thought we'd have to throw away, until we tried out a pair! These 1/2 foot long backings may look umusual, but their stopping power is immense!
Because of they use more Aluminium and due to the high cost of raw materials, these backings will be around £100 a pair. I'm sure riders will agree that they're worth the price when they try them out!
haha. I don't see how a company can one minute consider something useless and that they'd have to throw them away, to then charging £100 for them :giggle: Is this a wind up, or are Heatsink actually gunna sell these? Like is anyone here willing to buy these??
Cai.
Myself and a few others are waiting on our proto versions to arrive as we speak. :)
Should be able to fit around 3 whole pads in a single backing, increasing surface area (which, as every one knows, increases friction by a factor of three squared!!) and decreasing wear.
The additional performance will mean less effort to use the brakes, so less arm pump/fatigue in comps, and obviously the reduced wear is handy if you're running 6 pads each brake (initial tests seem to show such little wear that pads will last longer than 3 pairs of pads would on their own)!
Later prototypes/production models have a more curved shape to fit the rim though. Those pictured are the 'error batch' and as such are straight, for which you'd need a huuuuuuuge wheel to run them!
I'll report back after having a little while to run them (Y)
Nah man, 100% serious :)
At first it was just a cockup on the part of the machining unit and was considered useless, but after several long phonecalls and email discussions between Steve, myself and a few others we've crunched the numbers and run the FEA and think it could work pretty damn well!
Initial trials hope to confirm this in the very near future
Nah it's no piss-take, Steve is cutting up some extended Yellow material to fit in them properly right now!
He didn't realise how good they'd be, I should be getting one of the curved sets apparantly, can't wait!
Expect some amazing reviews in the pad reviews topic within the week. (Y)
Dave, we'll be looking into this issue as it definitely needs to be considered. The beauty of the 3-pad setup as opposed to a looooooong pad means you can run a selection of compounds. I know that I for one want to try a triple-compound setup, getting harder at the end where wear seems to be greatest.
This may not prove to be a major issue though, with the additional surface area leading to less wear in general (Y)
EDIT: the whole pads lasting 3 times longer thing sounds awsome too (Y)
Try to remember that you also have 3 times the amount of pads there though, so overall this cancels out to around the same frequency of replacing pads as normal
Well it's more pad on the rim = more stopping power. Should have been done a long time ago.
Penicillin was invented by mistake too and that's doing ok for itself.
Monty used to sell their pads in both 35mm and 50mm lengths so it's just an extension to that I guess. Good call on the multiple compounds thing too Luke, hadn't thought of that.
Edit: appears they still do!
The only problem I can see (apart form a bit of added mass obviously) is how the pad material actually wears. On standard size pads mine always seem to wear from one corner first rather than uniformly and I can only see this being worse with longer backings.
But if it has more friction, you'll be able to run a lighter grind or smooth surely, so they won't wear that much?3
I think the funny wear angle thing will be lessened over standard backings, because on standard pads they can roll more easily because the pressure fromthe piston is applied to the rim across a shorter legnth if you can see what I mean? With the backing being longer, it will have less leverage to rock it. It sounded better in my head!
Anyway, as luke said, you could have harder at the ends and softer in the middle, so at either end you could have Koxx Crocos for sheer hold, and in the middle Heatsink Yellows for massive bite, the possibilities are endless!
Has steve said anything more to you about the mod ones Luke? That only take 2 pads? If he had 3, the curve would have to be even sharper on a mod wheel and may well damage the slave. It's just I could use my brothers mod to test them, he's got a maggy on the back.
hahaha 100 quid a pair, im ordering 5 sets rofl
i no its all bull, but were there actually some made that long by mistake? or is that part of the joke story?
as you cant just press one button on a cnc machine and make it do summit like that xD
they'd look so funny :giggle:
