Woodstock
Hendrix
Due to the other thread containing a lot of abuse over previous issues, I've decided to start another thread - with new photos and specs!
Onza Woodstock
Frame: Onza Woodstock.
Forks: Phase Trials.
Headset: Caine Creek Internal.
Bars/Stem: MAD Trials, Riser Bars.
Cranks: Suntour Duo Trials. With Rockring and 22t Chainring.
Rear Wheel: Maverick 721 Rim On Revolver Hub - Michelin DH 24 Tyre.
Front Wheel: Alex DM18 On Unbranded Hub - Maxis High Roller.
Brakes: Magura HS33 - Front + Rear.
Gears: Sram 3.0 8 speed Shifter and Mech - ACS Claw Freewheel 16T.
Since the original photo was taken I've upgraded the rear wheel - fitted a booster - fixed the maggies - tensioned the chain & adjusted the bars.
The outcome:
Currently looking into getting some more stickers printed - and getting it re-sprayed. Either the original color, or white frame - black white forks & black accessories.
Edited by Hendrix
Carbon stem... Sounds like a bad idea to me.
Also why would you want to respray the bike in the original colour when it's already the original colour and looks pretty spotless to me?
Well, it's a seat stem - so it's just to cut down the weight on the rear, 'cause I'm a woos. :P
It's got some marks on it, but I'm thinking a color change with the original stickers could be different. As for the short term it's staying as it, noting lack of time and funds.. :(
Edited by Hendrix
Why do you have a shifter?? But a single speed hub??
Look's preety good thou, always had a soft spot for Woodstocks
Not had time to take it off, and get the mech stuck in place. Will be done in the next few weeks though. :)
Cheers man.
