How Tight Should A Chain Be!
0zzy
Personal preference is top answer.
TO tight and chain will snap.
TO loose and chain will come off.
The tighter it is the quicker engagement i believe?
Because it does not ahve to tighten the chain before it locks the freewheel. <--hope that makes sense.
And my uncle told me(he used to work with bikes) that a chain should only have half an inch in total movement either way.
Edited by bigamac
I think that if the chain's too loose it can cause a chain to snap; when gapping if you stamp down on the pedals you'll take up the slack in the chain meaning that when your hub/freewheel engages there will be more force going through the chain than if there was zero slack. There's a lot to be said for preloading of course.
I personally have always run my chains pretty tight, particularly on mod, but obviously not too tight so as to cause damage to bearings.
There has been talk of the Koxx guys running slack chains for certain reasons which I'm not 100% convinced by but then I guess they know their stuff!
Also, the half inch thing is for motorbikes more than anything, and certainly not for trials pushbikes I'd have thought.
I set my tensioner so the chain has about 5mm of up and down movement.
For reference: up and down movement on a motorbike is typically about 1.5 to 2 inches total movement, however a supermoto needs about 3" of movement :)
sumo's are 3"??
really? (not an expert just i'd have thought thats well slack and will flap and scrub the wide tyres?
my enduro bike runs with about 2 inches and i'd have thought that would require more then a motard?
anyway sorry i'm off topic, sprung tensioners:D
but i'd have said a bout a 1.5- 2 cm in total. thats what the bmx liked and how i'd set up a mod
i find the right tention is.......if you squeze your chain as if your squeazing it in to the chain stay it just wont quite touch (Y)
make any sence?
I like that idea. I'll check mine and see how it squares up to that method.
No expert here, but I leave mine so there's just an almost unnoticeable sag on the section of chain that runs under the chainstay.
Edited by Tappets
Im running my chain very tight for 3-4 years now, never snapped because of that i believe. I also use the same bb, rear hub for more than a year now, and they are still pretty smoth. I agree it will ruin the bearings, but to be honest, if its okay for a year and a half, than its worht it for me.
I set my chain so it's tight (No slack but not under serious tension) when it's at its loosest point. I use one of the Echo hubs with built in tensioner, so there's enough spring to not have the chain overtight when the cranks are turned to the highest tension position (Particularly with a front freewheel, the front sprocket is never perfectly centered on the crank, so the chain will change tension as you turn the cranks).
Flex in the frame/chain/BB/axles will make the lower run of chain slack while the upper run is carrying pedaling tension while the chain is initially tight anyway though.
since when have you liked it lose??????? ur chains so tight the wheel doesnt even spin once without stopping....... you already been told, no point asking the whole world you'll only get the same answer
Motorbikes (and any sus bikes) have large amounts of chain slack because the effective chain length changes throughout the travel of the swing arm, unless the drive sprocket is on the same axis as the swing arm.
When setting the tension on any chain it should not be super tight.
Someone mentioned half inch of movement somewhere, this is what old school fitters do when tensioning a chain drive on something like an industrial conveyor, this figure is the total flex in the chain UP and Down (not just down or not just up).
I would have said you can get away with a bit less.
Blah, blah,blah, poisonous monkey..............
Matt
