Wanting A Cordless Drill
dann2707
Can you not get a replacement battery for it? My dads had the same hitachi drill for about 15 years now, more than upto the job and all he's had to do is buy a new battery, he's also well into engineering and uses it for that a lot of the time. Find out what your dad's got and see if you can get a new replacement.
Yeah, probably.
It's funny, he always has a go at me when the battery is flat, thinking I've used it and not put it on charge yet i'm the one who always charges it fully. About time this situation is sorted. It's like a laptop battery when they die and you get like 1 mins use of it without the power cable.
That's true. A battery's easier to wrap as well.
An aids ridden cock is easily wrapped in an 'accidentally' split jonny.
Administering is more of an issue though, unless your family have that sort of relationship...
Hitatchi or DeWalt would be my choices, problem is that a proper cordless drill will cost way more than you want to spend.
If you want to sort out the charging issue, you could present your dad with a personalised 2012 calendar. Just take a picture of the battery in the charger and add caption along the lines of "have you charged me today?". Attatch the picture to the image below and you've got youself a brilliant hand made present which will help your family bond.
  • Like 1
But macallister are awful! If you are going to get budget, then Ryobi are about the best. They are usually on decent offers too, and the cordless one plus range all use the same batteries so you can get more bodies and use the same batteries :) Good for the not so hardcore user.
I have a ryobi set as well. The macA out-torques it every time. It'll nip up any screw a little tighter than the ryobi/B&D will.
im convinced macallister have 2 production lines, labelled "crap" and "brilliant" and everything just gets chucked in the same box. for some unknown reason we started getting macallister jigsaws through work, the first one worked fine for maybe 6 months, then met its end under a 18 tonne truck, the second one we got, lasted us about 2 weeks, and just became a paperweight. the third one is now knocking on for 5 years old, is used, abused, and lives in a workshop, used for cutting everything from steel, plastic, aluminium, hydraulic pipes(often full of oil, which then runs into the jigsaw), armoured cable, surrounded by brake dust, engine oil, etc and it just works.
